paolol61
Connect a second sensor
Tue Jun 26, 2018 12:46 pm
Hi, I'm new to eletronics, so it my be a stupid question but I will like to add a second sensor to my project .
I have a temperature sensor (AM2303) all works fine, but now I will like to add a second sensor (MQ135) , but don't know where I have to connect the output to the GPIO the other sensor is using pin 7.
pcmanbob
Re: Connect a second sensor
Tue Jun 26, 2018 2:32 pm
Hi.
Looking at the specifications for the MQ135, it looks to have a analogue voltage output that increases with the increase of gas concentration.
As the pi has no analogue ports you will need to add an analogue to digital converter like the MCP3008 to interface the sensor to your pi.
some examples of how to use the MCP3008 on the pi.
https://pimylifeup.com/raspberry-pi-adc/
http://www.instructables.com/id/ADC-MCP ... pberry-Pi/
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
The Traveler
Tue Jun 26, 2018 2:41 pm
Or purchase an Arduino which has built in analog inputs and interface it to a Raspberry Pi. A fairly common, but somewhat more complex solution.
Cheers.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
paolol61
Wed Jun 27, 2018 7:40 am
Hi thanks for reply , but still the question is where I can connect a second sensor??
I will use the MCP3008 as per the project but can I connect both signal to the pin 7 or I need to use a separate pin ??
scotty101
Wed Jun 27, 2018 8:34 am
A MCP3008 (or any SPI device) will connect to the SPI pins seen on this link https://pinout.xyz/pinout/spi
No conflict with pin 7.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
pcmanbob
Wed Jun 27, 2018 11:04 am
So the MCP3008 will connect to the following pins
VDD (Pin 16) wire this to 3.3V
VREF (Pin 15) wire this to 3.3V
AGND (Pin 14) wire this to ground
CLK (Pin 13) wire this to GPIO11 (Pin 23/SCLK)
DOUT (Pin 12) wire this to GPIO9 (Pin 21/MISO)
DIN (Pin 11) wire this to GPIO10 (Pin 19/MOSI)
CS (Pin 10) wire this to GPIO8 (Pin 24/CE0)
DGND (Pin 9) wire this to GROUND
you will then connect the analogue output of the sensor to one of the analouge input pins on the MCP3008, you will need to make sure the output of the sensor is limited to a maximum of 3v, so if the output is 0 to 5v then you will need to use a potential divider to reduce the voltage.
paolol61
Fri Jun 29, 2018 7:11 am
Thanks a lot
