Here's a diagram of my circuit using a 2N7000
I believe this should work but I'd like some confirmation. Thanks!
NOTE: Yes, I did totally miss the BBCode on the image hosting site. Sorry.
Diagram is at the URL above.
Really? The illustration now available in the first post looks completely weird (although I did say I have little experience of FETs). I would be happier with the source to ground and the load in the place of the drain resistor, I don't see how it could work as diagrammed. As shown, the drain resistor would seriously limit the performance, even if the FET did switch.
It's even worse than that - the gate-source voltage must be greater than VGS(th), which for the 2N7000 is between 1v and 2v5 (depending on the drain current), so the output to the speed control will be no more than a couple of volts.Z80 Refugee wrote: ↑Wed Jun 13, 2018 9:46 amSo, as illustrated, an enhancement FET will only turn on while the gate voltage is higher than the output, limiting the maximum output voltage at 3.3V
I don't think it will, and I seem to have some agreement on that. For some design principles on circuits I, personally, know will work, take a look at my guide: viewtopic.php?f=34&t=207597 (scroll down to "Hardware Interfacing").
