TomS-Uk
Wiring multiple i2c together
Sun Jun 10, 2018 7:50 pm
Hi all
I’m a regular forum viewer but this is my first post.
I’m building a sensor device and have wired 4 i2c devices together. I have wired from one SCL pin to another, sort of daisy chaining them together. The same for SDa Vin and Gnd. However none are detected on my pi.
I’m a novice when it comes to electronics and I’m learning as I go.
Should this setup work?
Tom
joan
Re: Wiring multiple i2c together
Sun Jun 10, 2018 9:23 pm
No reason it shouldn't work.
For safety all your devices should be 3V3.
Could you show either a photo of your connections or a detailed schematic?
TomS-Uk
Mon Jun 11, 2018 11:19 am
Thanks for the reply
I can't upload the image as it's saying it's too large but here is the link
https://1drv.ms/u/s!ArKqRmWga3sHgYJUO0MkuBSqeWkd5g
I plan on doing some testing with it tonight I just wondered if I've even wired it correctly
Tom
Bruce_Pi
Mon Jun 11, 2018 5:25 pm
did you check the pull ups ?
I2C wont work untill you pull SDA and SCL lines high. A 4.7K will be a good choice.
TomS-Uk
Mon Jun 11, 2018 9:54 pm
I sorted it. I de-soldered the connection to my Pi and tested them on a breadboard. They work fine in that configuration so I must have had a dodgy solder joint or something :lol:
TomS-Uk
Mon Jun 11, 2018 9:55 pm
They work without any resistors? I thought a pi has pull ups built in?
joan
Mon Jun 11, 2018 10:06 pm
Yes, the Pi has 1k8 resistors between GPIO 2/3 and 3V3 specifically for I2C.
