ricardo.santos
BME280 not detected via i2cdetect and heats a lot
Mon Jun 04, 2018 5:42 pm
Hi
i'm trying to connect the BME280 (temp+hum+press) sensor to raspberry Pi3B with I2C
Here is my connections https://github.com/Ricardosgeral/relier ... relier.png
I've connected VCC to 5V (specs say 1.8 to 5V) but i know most of people use the 3.3V. But I thought that should work as well...
The problem is that it does not work. I don't see the address when I do sudo i2cdetect -y 1. But I can see the address for the other I2C device (ADS1115).
Another thing. The sensor heats up to 50 degrees....That should not happen right?
If I connect to 3.3v i can't detect it as well and the sensor becomes also very hot (I've measured 40 degrees with multi-meter)
Any ideas? Is the sensor faulty? I'm i doing anything very wrong?
Anyone experienced this?
thanks
Re: BME280 not detected via i2cdetect and heats a lot
Mon Jun 04, 2018 6:22 pm
Faulty sensor is the most likely fault. Abuse of Vdd is most likely cause.
BME280 datasheet wrote:The sensor provides both SPI and I²C interfaces and can be supplied using 1.71 to 3.6 V for the
sensor supply VDD and 1.2 to 3.6 V for the interface supply VDDIO. Measurements can be
triggered by the host or performed in regular intervals. When the sensor is disabled, current
consumption drops to 0.1 µA.
This is a doctor free zone.
ricardo.santos
Mon Jun 04, 2018 6:34 pm
:shock: ok. I guess I killed it
thanks
Mon Jun 04, 2018 6:36 pm
The Adafruit breakout board includes a small voltage regulator so you can power those with 5V.
