rmix
Incorrect values on GPIO without ground
Mon Mar 19, 2018 10:19 pm
please, when I read GPIO pin:
- empty - read 0 - correct
- connected to +3,3 V - read 1 - correct
- connected to GND - read 0 - correct
- connected to free cable (with unconnected second end) - read 0/1 with high frequency change - WHY?
How it's possible read still zero on unconnected (ungrounded) pin?
I read value through python RPi.GPIO:
while True:
	print GPIO.input(7)
Thanks!!
scotty101
Re: Incorrect values on GPIO without ground
Tue Mar 20, 2018 10:03 am
These unconnected pins are known as floating pins or floating inputs. An unconnected pin is a little antenna that picks up electrical interference from other ICs on the same board, other devices or just background interferance.
https://learn.adafruit.com/circuit-play ... ing-inputs
https://www.mouser.com/blog/dont-leave- ... s-floating
This is why we use pull up/pull down resistors.
