NareshLCS
Bluetooth audio over PCM/I2S (HF Profile)
Sun Mar 04, 2018 9:46 am
I'm trying to connect to a Bluetooth headset using the HF profile and I would like to route the audio using PCM/I2S interface (and not using SCO Over HCI).
Few questions regarding that:
1. Is the BCM2837 PCM line connected to BCM43438 ?
2. Are the PCM/I2S drivers available to enable routing of audio to the BT chip ?
Thanks!
Naresh
tiim21
Re: Bluetooth audio over PCM/I2S (HF Profile)
Fri Sep 07, 2018 11:55 am
I have exactly the same problem.
Did you find some information?
BR
Tomasz
