Killertechno
[kernel] Permissions of character device?
Mon Feb 19, 2018 4:58 pm
Hi to all, I wrote a kernel driver some time ago, now not working at all (I suppose due kernel/OS changements).
After some copy&paste&try work I finally got my kernel driver working (more or less) driving GPIO pins as I need.
static dev_t first;
static struct cdev c_dev;
static struct class *cl;
static int __init qcnsync_init(void)
	int ret;
	struct device *dev_ret;
	contatore = 0;	// lo uso io, per debug
	if ((ret = alloc_chrdev_region(&first, 0, 1, "my_chrdev_region")) < 0)
		return ret;
	if (IS_ERR(cl = class_create(THIS_MODULE, "my_class")))
		unregister_chrdev_region(first, 1);
		return PTR_ERR(cl);
	if (IS_ERR(dev_ret = device_create(cl, NULL, first, NULL, "qcnsync")))
		class_destroy(cl);
		return PTR_ERR(dev_ret);
	cdev_init(&c_dev, &fops);
	if ((ret = cdev_add(&c_dev, first, 1)) < 0)
		device_destroy(cl, first);
		class_destroy(cl);
		return ret;
	printk(KERN_INFO "[qcnsync] <qcnsync_init>: driver initializing sequence done");
	return 0;
In this case I can create /dev/qcnsync character device, and I can read it:
sudo cat /dev/qcnsync
[email protected] ~/mykernel2/qcnsync $ sudo cat /dev/qcnsync
Hello world!
Now I would like create character device I can read from common user (without sudo).
I'm confused about major/minor.
I found this code:
// see linux/Documentation/devices.txt (240-254 char = LOCAL/EXPERIMENTAL USE)
// use 0 for dynamic
#define DEV_MAJOR	240
#define DEVICE_DESC 	"QCN sync"
static char *qcnsync_devnode(struct device *dev, umode_t *mode)
        if (!mode)
            return NULL;
        if (dev->devt == MKDEV(DEV_MAJOR, 0) || dev->devt == MKDEV(DEV_MAJOR, 2))
                *mode = 0666;
        return NULL;
		return PTR_ERR(cl);
	// per i permessi di lettura
	cl->devnode = qcnsync_devnode;
I still need to use sudo, while:
        if (!mode)
            return NULL;
                *mode = 0666;
        return NULL;
Correctly works without sudo, but I suppose isn't safe.
Sho what's correct code?
Thansk.
Who is online
Users browsing this forum: No registered users and 5 guests
