uranusb
CAN-FD with Raspberry Pi 3
Tue Feb 06, 2018 4:05 am
Hi everyone,
I am a beginner in raspberry pi and linux. Currently, I am working on implementing a CAN-FD board (click MCP2517FD board with MCP2517FD controller and ATA6563 transceiver) on raspberry pi 3 by using SPI interface. I completed the connection and tested the board following the same steps of implementing CAN (mcp2515) on the raspberry pi:
1.
sudo apt-get update
sudo apt-get upgrade
sudo reboot
2. Add three lines in config.txt
dtparam=spi=on
dtoverlay=mcp2517fd-can0,oscillator=16000000,interrupt=25
dtoverlay=spi-bcm2835-overlay
3. Test CAN
sudo /sbin/ip link set can0 up type can bitrate 500000
However, it keeps telling me that cannot find device "can0", then I tried some other methods, such as removing "-overlay" or fixing the name of the controller from "mcp2517fd" to "mcp2517" in config.txt, but got the same result.
I also checked the available interfaces by using "ifconfig -a" and found that there is no CAN interface. So I just want to know, does anyone here have the experience of implementing CAN-FD on the raspberry pi or does anyone here can give me some suggestions?
Thank you.
PeterO
Re: CAN-FD with Raspberry Pi 3
Tue Feb 06, 2018 9:21 am
Have a look at sk pang's web site, there may be some tips on using his boards that might help you.
http://skpang.co.uk/catalog/pican2-canb ... -1475.html
PeterO
uranusb
Tue Feb 06, 2018 3:00 pm
PeterO
Thanks for your reply. Actually, I was working on PiCAN2 board before, it worked fine with mcp2515, but when I tried to modify the code and applied it over mcp2517fd, I failed. It seems that the system can't detect the CAN core.
jbholtz
Tue Jun 12, 2018 4:45 pm
Has this been solved. I also have a PiCAN-FD from CopperHill/SPK and trying to setup my RPI3+. Thanks for any information that has already been shared. I've been looking around for any information
bertr2d2
Wed Jun 13, 2018 4:04 am
Easy to build CAN-Bus interface:
http://lnxpps.de/rpie
