astirfreak
SPI1 works, but CS0 not
Sat Jan 27, 2018 4:34 pm
I have PI2+, with a working waveshare display clone. To control a second SPI device (potentiometer) I like to use SPI1.
In the config.txt I added
dtoverlay=spi1-1cs
To control the SPI, I use Python with spidev.
My testcode is:
import spidev
spi = spidev.SpiDev()
spi.open(1,0)
spi.max_speed_hz=50000
spi.cshigh=False 			# |
spi.cshigh=True 			# -> No effect if one of this lines is used
spi.xfer([0xAA])
spi.close()
I can see clock on DCLK (Pin 40) and data an MOSI (Pin 38).
On pin 36 (SPI1_CS0) I cannot see anything. It has a constant low level.
To check, if there is a hardware problem I tried:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(16, GPIO.OUT)
GPIO.output(16,1)
With that code I can see, the pin 36 (GPIO16) is working.
Whats wrong here?
Michael
astirfreak
Re: SPI1 works, but CS0 not
Sat Jan 27, 2018 5:01 pm
dtoverlay=spi-gpio35-39
doesn't work for me.
The display then doesn't work anymore and no spi is visible in /dev
astirfreak
Sat Jan 27, 2018 5:20 pm
Further findings:
https://pinout.xyz/pinout/spi#
It uses the CS0 on Pin12 (GPIO18). I can see it on this pin with my oscilloscope.
Pin 36 isn't CS0 for SP1 as mentioned in
Pin 12 is blocked by the display.
To use Pin 36 instead I have to create an own overlay. Now I have to google how to do that.
Michael
astirfreak
Sat Jan 27, 2018 5:35 pm
Does anyone know, where to find the original code of spi1-1cs.dtbo?
I only find the precompiled versions but I want to modify it and compile it by myself.
Michael
ericcooper
Sat Jan 27, 2018 6:13 pm
It's in arch/arm/boot/dts/overlays/ on https://github.com/raspberrypi/linux, rpi-4.9.y branch
astirfreak
Sat Jan 27, 2018 7:34 pm
Thank you, now I got it working:
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        spi1_pins: spi1_pins {
                                brcm,pins = <19 20 21>;
                                brcm,function = <3>; /* alt4 */
                        spi1_cs_pins: spi1_cs_pins {
                                brcm,pins = <16>;
                                brcm,function = <1>; /* output */
        [email protected] {
                target = <&spi1>;
                frag1: __overlay__ {
                        /* needed to avoid dtc warning */
                        #address-cells = <1>;
                        #size-cells = <0>;
                        pinctrl-names = "default";
                        pinctrl-0 = <&spi1_pins &spi1_cs_pins>;
                        cs-gpios = <&gpio 16 1>;
                        status = "okay";
                        spidev1_0: [email protected] {
                                compatible = "spidev";
                                reg = <0>;      /* CE0 */
                                #size-cells = <0>;
                                spi-max-frequency = <125000000>;
                                status = "okay";
        [email protected] {
                target = <&aux>;
                __overlay__ {
                        status = "okay";
        __overrides__ {
                cs0_pin  = <&spi1_cs_pins>,"brcm,pins:0",
                           <&frag1>,"cs-gpios:4";
                cs0_spidev = <&spidev1_0>,"status";
I only replaced the two entrys of the CS-Pin from 18 to 16.
If the the device tree compiler is not installed it has to be installed:
sudo apt-get install device-tree-compiler
After that I compiled my dts:
 dtc [email protected] -I dts -O dtb -o spi1-1cs36.dtbo spi1-1cs36.dts
spi1-1cs36.dtbo: Warning (unit_address_vs_reg): Node /[email protected] has a unit name, but no reg property
I got that warnings but I ignored it.
Now the dtbo has to be copied:
sudo cp spi1-1cs36.dtbo /boot/overlays
The last step is to add it to the boot.cfg:
sudo nano /boot/config.txt
And here I added a new entry as last line:
dtoverlay=spi1-1cs36
vybhav
Thu Mar 22, 2018 7:19 am
Hi
I made the above changes (dtoverlay=spi1=1cs) in the config.txt.
In the program when i wrote spi.open(1,0) i am getting an error "[Errorno2] no such file or directory "
can anyone help me out in using spi1(python code)
Thank you
