jamjammers007
how to solve; VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
Thu Jan 25, 2018 1:05 pm
Unable to stop the stream: Device or resource busy
6by9
Re: how to solve; VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
Thu Jan 25, 2018 2:33 pm
What V4L2 device? What format?
"v4l2-ctl -V" will print out the currently selected resolution and format. At a guess it's a webcam putting out H264 (Logitech C920?) and OpenCV can't support that. "v4l2-ctl --list-formats" will list out all the formats your device supports. It is possible that it really doesn't have a compatible format.
("sudo apt install v4l-utils" if v4l2-ctl is not already installed).
Call Me Adept
Wed Feb 14, 2018 11:48 am
I have the same problem and I'm still unable to find a solution anywhere.
6by9
Wed Feb 14, 2018 1:44 pm
And yet you haven't answered any of the questions I asked the original poster.
Same questions to you - what device, and what format? "v4l2-ctl -D" and "v4l2-ctl -V"
(OP hung around the forums for 10 minutes after posting and hasn't returned since - I sometimes wonder why we bother).
Call Me Adept
Wed Feb 14, 2018 1:47 pm
I got it to work now. Sorry for not giving enough information and thanks for replying
6by9
Wed Feb 14, 2018 2:40 pm
So help out those who find themselves in the same situation in future, and say what you did to solve it.
aardvarko
Fri Mar 23, 2018 12:25 am
I am running into this too, with a SD image migrated from a Pi 3 to a Pi 3 B+. Any guesses what you did to fix it?
aardvarko
Fri Mar 23, 2018 1:05 am
my machine was having camera module problems, turns out. this was opencv's way of saying "halp" altogether. I reenabled the camera module in raspi-config and reseated the fpc and it is no longer causing this yack.
111Muhammad
Mon Apr 01, 2019 6:37 pm
i am having the same problem. please share it with us. thanks.
projectdrone2
Thu May 02, 2019 4:47 pm
@Call Me Adept, could you please share how you fixed the issue? Thanks in advance.
@aardvarko, what do you mean by
reseated the fpc
projectdrone2
Thu May 09, 2019 9:00 pm
I found a workaround which is to open and immediately close a cam then reopen it!
so instead of
cam = cv2.VideoCapture(0)
do
cam.release()
Hope it works for you as well!
