SPI OLED SSD1306
Posted: Tue Jan 23, 2018 2:03 am
by netsleb229
Hi, Im trying to use a monochrome 128x64 OLED display with my raspberry pi 3 and I am having some issues. l followed this https://learn.adafruit.com/ssd1306-oled ... lack/usage tutorial but when I try to run
sudo python shapes.py
I get this error:
File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/SPI.py", linne 42, in __init__ IOError: [Error 2] No such file or directory
The linux-armv7l directory appears to be empty.
Thanks for any help in advance, Alex
Re: SPI OLED SSD1306
Posted: Tue Feb 20, 2018 9:24 pm
by twinkle
Did you enable SPI in raspi-config and change to the correct disp type in shapes.py?
Posted: Sat Dec 15, 2018 2:39 pm
by ambaltose
I have the same problem, I activated SPI in config and the code uses the correct display but when I run the code, nothing happens. I followed the same instructions at Adafruit but the display shows nothing. Tested it also on my arduino, no issues there, so the display itself is working.
Thanks for any help,
AMB
