diyquad
Serial Pin & Python
Fri Dec 01, 2017 1:42 pm
i'm trying to connect a Flight Controller, using Mavling or LTM (communication protocol) to my Raspberry.
I have to connect to pin RX/TX (14/15) to send data to raspberry and play with it in Python.
But when i try to open the serial port, i always get this message
TypeError: 'Serial' object is not callable
Here is my code
import serial
import time
ser = serial.Serial('/dev/ttyAMA0',57600,timeout=None)
time.sleep(0.3)
byte_read = tel_sock()
print (byte_read)
Don't know what to do about that
dgordon42
Re: Serial Pin & Python
Mon Dec 04, 2017 3:37 pm
Which model of Raspberrypi are you using?
Which Operating System are you running on this Pi?
What have you done (if anything) to configure your Pi for Serial Port operations?
Thanks,
Dave.
Who is online
Users browsing this forum: No registered users and 12 guests
