alxsoa
CCS811 Driver
Sat Nov 04, 2017 9:07 am
Hi All,
I looking to complete my project, an library for use in C or C++ to access the values from CCS811,
bitbank
Re: CCS811 Driver
Sun Nov 05, 2017 2:50 pm
I just released such a library here: https://github.com/bitbank2/CCS811
It has a simple C interface and will do what you want. I found that there are lots of read errors on Raspberry Pi boards. Others have commented that this has something to do with "clock stretching". I also connected it to my Orange Pi boards and did not experience the errors.
The fastest code is none at all :)
paulvha
Re: CCS811 Driver
Sun Dec 10, 2017 5:48 pm
Fully agree with bitbank about the read errors. BUT this is NOT a Linux driver problem. I use the BCM2835 library (which works directly on the hardware and does NOT use the drivers). The issue is the CCS811 itself. I have bought the Sparkfun combo breakout. It has the CCS811 and the BME280 (to use for compensation). The later works as a star as other i2C devices . The CCS811 gives random NACK or invalid readings, sometimes even at the speed of 10K. I had to include extra delays, and retry-counts, to get stable information. As a result I got it running at 400KHZ (which is the maximum for this sensor). Apart from it is a good sensor.. but make sure to readings/calculations right.
Who is online
Users browsing this forum: No registered users and 18 guests
