inky699
SPI errors using spidev
Mon Jul 17, 2017 1:04 pm
Greetings all, I have used the SPI loopback test program from the https://www.raspberrypi.org/documentati ... /README.md page . I can open the SPI device, set the bits and set the frequency, but when I try to set the mode, I get an error. dmesg shows "spidev spi0.0: setup: unsupported mode bits 20".
I have added group spi to the pi users group list,
ls -al /dev/spi*
crw-rw---- 1 root spi 153, 0 Jul 14 16:45 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 Jul 14 16:45 /dev/spidev0.1
static const char *device = "/dev/spidev0.0";
static uint8_t spi_mode = SPI_LOOP | SPI_MODE_0;
static uint8_t bits = 8;
static uint32_t speed = 8000000; // 8MHz
static uint16_t delay;
int spiInit(void)
	int spi_filestream;
	int ret;
	spi_filestream = open(device, O_RDWR);
	if (spi_filestream < 0)
		printf("\n\n***********\ncan't open device - (%i)\n***********\n\n", spi_filestream);
	 * spi mode
	//ret = ioctl(spi_filestream, SPI_IOC_WR_MODE32, &mode);
	ret = ioctl(spi_filestream, SPI_IOC_WR_MODE, &spi_mode);
	if (ret == -1)
		printf("can't set spi mode to %d\n", spi_mode);
	ret = ioctl(spi_filestream, SPI_IOC_RD_MODE, &spi_mode);
	if (ret == -1)
		printf("can't get spi mode\n");
	 * bits per word
	ret = ioctl(spi_filestream, SPI_IOC_WR_BITS_PER_WORD, &bits);
	if (ret == -1)
		printf("can't set bits per word\n");
	ret = ioctl(spi_filestream, SPI_IOC_RD_BITS_PER_WORD, &bits);
	if (ret == -1)
		printf("can't get bits per word\n");
	 * max speed hz
	ret = ioctl(spi_filestream, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
	if (ret == -1)
		printf("can't set max speed hz\n");
	ret = ioctl(spi_filestream, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
	if (ret == -1)
		printf("can't get max speed hz\n");
	printf("Read from SPI:\nspi mode: %d\n", spi_mode);
	printf("bits per word: %d\n", bits);
	printf("max speed: %d Hz (%d KHz)\n", speed, speed/1000);
	return spi_filestream;
} // spiInit()
int spiTransaction(int spi_filestream, unsigned int nosBytes, uint8_t *pcTxBuf, uint8_t *pcRxBuf)
	int ret;
	// structure used to transfer the data to the Linux driver
	struct spi_ioc_transfer tr = {
		.tx_buf = (unsigned long)pcTxBuf,
		.rx_buf = (unsigned long)pcRxBuf,
		.len = nosBytes,
		.delay_usecs = delay,
		.speed_hz = speed,
		.bits_per_word = bits,
	if (spi_filestream >= 0)
		ret = ioctl(spi_filestream, SPI_IOC_MESSAGE(1), &tr);
		if (ret < 1)
			printf("can't send spi message");
			return -1;
		for (ret = 0; ret < nosBytes; ret++) {
			if (!(ret % 6))
				puts("");
			printf("%.2X ", pcRxBuf[ret]);
	} else
		printf("!!! No SPI device\n");
	return 0;
} // spiTransaction()
On the console, I get:
can't set spi mode to 32
Read from SPI:
spi mode: 0
bits per word: 8
max speed: 8000000 Hz (8000 KHz)
Does someone know what I am doing wrong and how to fix it?
System:
- RaspberryPi3
- raspbian jessie (kernel 4.9.28v7+ #998 SMP Mon May 15 16:55:39)
Modules:
Module                  Size  Used by
nls_utf8                1656  2
ntfs                  248169  2
bnep                   12051  2
hci_uart               19956  1
btbcm                   7916  1 hci_uart
bluetooth             365511  22 hci_uart,bnep,btbcm
brcmfmac              222874  0
spidev                  7373  0
brcmutil                9092  1 brcmfmac
cfg80211              543027  1 brcmfmac
rfkill                 20851  4 bluetooth,cfg80211
snd_bcm2835            24427  1
snd_pcm                98501  1 snd_bcm2835
snd_timer              23904  1 snd_pcm
i2c_bcm2835             7167  0
snd                    70032  5 snd_timer,snd_bcm2835,snd_pcm
bcm2835_gpiomem         3940  0
spi_bcm2835             7596  0
uio_pdrv_genirq         3923  0
fixed                   3285  0
uio                    10204  1 uio_pdrv_genirq
i2c_dev                 6913  0
fuse                   99603  3
ipv6                  406751  48
Re: SPI errors using spidev
Mon Jul 17, 2017 8:39 pm
Here's a sample of opening an SPI device and writing a byte to it. The most important part is the memset() call
#include <fcntl.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <stdint.h>
#include <time.h>
#include <sys/ioctl.h>
#include <linux/spi/spidev.h>
static char *spiDevice = "/dev/spidev0.1";
static uint8_t spiBPW = 8;
static uint32_t spiSpeed = 5000000;
static uint16_t spiDelay = 0;
int
spi_open (char *dev)
  if ((spi_fd = open (dev, O_RDWR)) < 0)
      printf ("error opening %s\n", dev);
      return -1;
  return 0;
static void
writeByte (uint8_t reg, uint8_t data)
  uint8_t spiBufTx[3];
  uint8_t spiBufRx[3];
  struct spi_ioc_transfer spi;
  memset (&spi, 0, sizeof (spi));
  spiBufTx[0] = CMD_WRITE;
  spiBufTx[1] = reg;
  spiBufTx[2] = data;
  spi.tx_buf = (unsigned long) spiBufTx;
  spi.rx_buf = (unsigned long) spiBufRx;
  spi.len = 3;
  spi.delay_usecs = spiDelay;
  spi.speed_hz = spiSpeed;
  spi.bits_per_word = spiBPW;
  ioctl (spi_fd, SPI_IOC_MESSAGE (1), &spi);
int
main()
  spi_open (spiDevice);
  writeByte (IODIRB, 0x00);
inky699
Mon Jul 17, 2017 9:00 pm
Thanks for the reply :)
I had seen the memset() thing before, but that doesn't explain why I can not set the mode after opening the device. I would like to do the looptest.
I will add in the memset() and see if I get data on the lines.
Ian
inky699
Tue Jul 18, 2017 8:06 am
Added the memset() before setting other variables, no change.
As expected, I still get the printf() for the unable to set mode to loopback (mode 32).
I still get the same error on transmit "can't send spi message".
So, what is different in my setup from 'working' set ups and how to fix it?
notro
Tue Jul 18, 2017 9:24 pm
The spi controller driver spi_bcm2835 doesn't support SPI_LOOP, so if you look in the kernel log (dmesg), you will probably see: setup: unsupported mode bits
SPI_LOOP is for controllers that can do internal loopback.
inky699
Wed Jul 19, 2017 7:44 am
OK, thanks for that. As stated in my original post, I did see that message.
Taken it out, added a jumper wire, so it 'loops back', but I still can't send messages - according to the command line, the ioctl() returns -1
Looking on my logic analyser, nothing is coming out of the SPI, no clocks or cs, let alone data.
So, I conclude the way I set the data up for the SPI transaction must be incorrect. Seen different ways of setting it up. The example I used, had one struct for the entire message (but that also had the SPI_LOOP....), other ways I've seen are more an array of structs for the SPI. So, for 10 data bytes, a 10 element array of transfer structs. Going to play with this for a while......
notro
Wed Jul 19, 2017 2:18 pm
If you print errno, you'll see the actuall error returned from spidev.
Armed with that you can look at the spidev code to see if you can find out why: http://elixir.free-electrons.com/linux/ ... dev.c#L356 (spidev_ioctl())
inky699
Wed Jul 19, 2017 2:38 pm
What I expected, I get -1 returned, so that is EPERM, or sod off, yo are not allowed to do that.
Hmm, so, even though I have permissions set (user pi has groups pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi) and the spi devices are crw-rw---- root spi, then I should have access.......
So, problem is here
/* Check access direction once here; don't repeat below.
	 * IOC_DIR is from the user perspective, while access_ok is
	 * from the kernel perspective; so they look reversed.
	if (_IOC_DIR(cmd) & _IOC_READ)
		err = !access_ok(VERIFY_WRITE,
				(void __user *)arg, _IOC_SIZE(cmd));
	if (err == 0 && _IOC_DIR(cmd) & _IOC_WRITE)
		err = !access_ok(VERIFY_READ,
	if (err)
		return -EFAULT;
Why does my code cause this?
notro
Mon Jul 24, 2017 2:27 pm
Is errno -1 or does ioctl() return -1?
inky699
Mon Jul 24, 2017 3:21 pm
ioctl() returns -1
I assumed from the code snippet in the driver, they are the same......
notro
Tue Jul 25, 2017 5:00 pm
You have to look at errno to know the real error code: https://linux.die.net/man/3/errno
