Killertechno
Re: ENC28J60 SPI Ethernet
Thu Nov 22, 2018 4:10 pm
Here picture of board.
DirkS
Thu Nov 22, 2018 4:18 pm
Killertechno wrote:
Thu Nov 22, 2018 3:54 pm
DirkS wrote:
Thu Nov 22, 2018 10:57 am
Did you enable SPI with 'sudo raspi-config'?
Obviously, I followed guides on connecting ENC28J60 on Raspberry forum.
Maybe obvious to you but not to me...
And that does not mean it's connected correctly...
More questions:
What device is eth2?
Is the internal device (eth0) connected to your router?
If not: does it get an IP address when you connect it to the router?
Have you tried a different network cable?
Did you make any changes to /etc/network/interfaces and or /etc/dhcpcd.conf?
Killertechno
Thu Nov 22, 2018 9:49 pm
I'm not used to connect devices randomly....
eth2 is usb to lan converter.
I already changed ethernet cable, tested straight and cross, changed router port.
dhcpconf.d is the default of Debian image (2018-april).
DirkS
Thu Nov 22, 2018 9:50 pm
I'm a troubleshooter... I'm used to people making mistakes
DirkS
Thu Nov 22, 2018 10:00 pm
And what about eth0? Does it get a DHCP address if you connect it to the router?
dhcpconf.d
You may not connect devices randomly, but you're not very precise with other things...
BTW: I would mask that IP address on eth2. It seems to be an external address.
Killertechno
Fri Nov 23, 2018 8:40 am
All ethernet ports (eth0, eth2) goes to two router: same dhcp server configuration, just different networks. Working. Only ENC20J60 module not working at all.
DirkS
Fri Nov 23, 2018 8:46 am
Well, can't think of anything else ATM, especially since your answers are very low on useful information.
Killertechno
Fri Nov 23, 2018 6:34 pm
What do you mean?
DirkS
Fri Nov 23, 2018 7:04 pm
What do you mean?
Well, answers as 'it works' and along the lines of 'I don't make mistakes' don't really help.
The more details you give the better the chance someone sees something odd and you can home in to a solution.
Also answers like
lack any significant information.
Good luck with finding a solution.
I hope someone else can help you with that.
