Danielya
Both speaker and microphone via I2S
Sun May 14, 2017 4:54 am
Hello there,
I've connected a speaker module (Hifiberry DAC) to the Rpi via I2S and it's working ok.
Now I'm trying to connect a microphone also via I2S. What I did was following the instructions in the following page:
https://learn.adafruit.com/adafruit-i2s ... g-and-test
Somewhere in the middle, it says:
Download the module, written by Paul Creaser
git clone https://github.com/PaulCreaser/rpi-i2s-audio
cd rpi-i2s-audio
make -C /lib/modules/$(uname -r )/build M=$(pwd) modules
sudo insmod my_loader.ko
Verify that the module was loaded:
lsmod | grep my_loader
dmesg | tail
But in dmesg I get:
bcm2835-i2s 3f203000.i2s: Trying to bind component to card "snd_rpi_simple_card" but is already bound to card "snd_rpi_hifiberry_dac"
It seems that the mic is trying to bind to the same sound card the speaker is bound to. What can I do? Is there another option to connect both mic and speaker to I2S?
Thanks.
laagland
Re: Both speaker and microphone via I2S
Tue May 23, 2017 8:34 am
Did you find an answer to this? I'm running into the same problem
Vincent209
Tue Sep 19, 2017 7:17 pm
Any answer on this one? I've just encountered the same..
mayurharge
Fri Jul 13, 2018 8:38 am
I have found a way to get this done!
so I have followed this tutorial guide from Adafruit https://learn.adafruit.com/adafruit-i2s ... g-and-test for Microphone
and this one https://learn.adafruit.com/adafruit-max ... -pi-wiring for the speaker.
So things to Consider are
1. BLK and LRCL pins are common for both speaker and microphone
2. Dout pin from the microphone is connected to the pin #38 GPIO-20
and Din pin of i2s Amplifier is connected to the pin#40 GPIO-21
Note: I have set up my microphone first and then i2s speaker
and it worked without any problem
stanbenj
Thu Jul 26, 2018 6:48 pm
Hello Dear
I've followed the process but once I restarted the Pi zero, the microphone stopped working. Is yours still working perfectly? I mean, can you use both micro and speaker on a PI?
Yumanook
Sun Aug 12, 2018 8:08 am
Hello yea I um am doing the same thing as you guys but I still get the error "bcm2835-i2s 20203000.i2s: Trying to bind component to card "snd_rpi_simple_card" but is already bound to card "snd_rpi_hifiberry_dac"". I also set up my speaker first, then the mic. Can you tell us how you got this to work? Thanks!
mayurharge
Fri Sep 14, 2018 5:40 am
I have not tested this on raspberry pi zero w. With raspberry pi 3 it worked without a problem after restarting the device also.
I am using raspbian Jessie image on my pi.
I guess you're not using the commands for microphone correctly.
I will update the commands for accessing the microphone one i complete tests on rpi zero.
Who is online
Users browsing this forum: No registered users and 7 guests
