Hi, first post here
I have a small display straight from a factory meant for use with VR headsets.
I could get a hdmi driver board for it but that's a bit of an overkill and I'm afraid of it adding delay as lag causes motion sickness in VR.
It's a 39 pin 12mm wide ribbon cable, they say 'mipi dsi'.
I need to use this display because of its pixel density.
Is it possible to connect it directly to a raspberry with some kind of plain adaper cable or does it have to go through some microprocessor and circuit board?
