lcharpen2
Re: Add an I2S mic using device tree & simple-audio-card
Wed Apr 05, 2017 9:54 am
Hello
Based on this project, I want to integrate the I2S SPH0645LM4H MIC on my raspberry PI 3.
I tried many things but there's only noise coming from the MIC. I made the test with another MIC (ICS43434) and it's working.
Based on this, I suppose something is wrong in the code...
Here is my configuration:
#define SPH0645LM4H_RATE_MIN 16000 /* Hz, from data sheet */
#define SPH0645LM4H_RATE_MAX 64000  /* Hz, from data sheet */
//this is 32 with 8 last bits always to 0
#define SPH0645LM4H_FORMATS (SNDRV_PCM_FMTBIT_S32_LE | SNDRV_PCM_FMTBIT_S24_LE | SNDRV_PCM_FMTBIT_S16_LE)
static struct snd_soc_dai_driver sph0645lm4h_dai = {
	.name = "sph0645lm4h-hifi",
	.capture = {
		.stream_name = "Capture",
		.channels_min = 1,
		.channels_max = 2,    //should be empty
		.rate_min = SPH0645LM4H_RATE_MIN,
		.rate_max = SPH0645LM4H_RATE_MAX,
		.rates = SNDRV_PCM_RATE_CONTINUOUS,
		.formats = SPH0645LM4H_FORMATS,
    //.sig_bits = 24,
Then, to record
arecord -Dplughw:1 -c2 -r48000 -fS16_LE -twav -d10 -Vstereo test2.wav
I changed fS16_LE to fS24_LE to fS32_LE without success.
Any idea of what's going wrong in my case?
Thanks for your help
robertguy09
Thu Apr 06, 2017 5:21 am
Still can't get the mics to work, but I found another weird issue that I hope will help narrow my problem down.
When I set the SEL pin to 3.3v and do a recording, the left channel on the recording peaks at 99%.
When I set the SEL pin to gnd and do a recording, the left channel on the record stays at 25%.
Can anyone think of a reason why this would be?
I am trying it with these Adafruit I2S mics.
https://www.adafruit.com/products/3421
robertguy09
Tue Apr 11, 2017 6:24 pm
I think I figured out the problem. The clock needs to be ~2-4 MHz.
I am not sure what the Pi's clock is set to, but I tested it with the audio library on a Teensy 3.2 and had the exact same problem I had on the Pi (SEL to gnd, left constantly 25%. SEL to 3.3V, left peak at 99%). With the Teensy, the clock is 1.41MHz. So that leads me to conclude the clock was the issue.
I got some ICS43432 mics and everything is working fine with them. Only the SPH0645LM4H are giving me a problem.
Anyone know what the clock is set to on the Pi?
Also, anyway to set the clock for I2S? I couldn't find where it was set from looking through the C file.
gregeric
Wed Apr 12, 2017 12:03 am
One difference I can see on looking at the datasheets is that the Knowles mic appears to output its data one half a bit clock earlier, 180° out of phase (starting on a CLK high, not low like the Invensys mic). I only have Invensys ICS43432 mics, so cannot do any further comparisons.
robertguy09
Thu Apr 20, 2017 12:00 am
Has anyone gotten this setup to work with Amazon's Alexa voice services?
Danielya
Mon May 15, 2017 8:42 am
Composit wrote:The project is about an intercom solution. So record and playback should be on simoultaneously.
I can load both dtoverlays - looks like this:
pi@raspberrypi:~ $ sudo dtoverlay -l
Overlays (in load order):
0:  i2s-soundcard  alsaname=mems-mic
1:  hifiberry-dac
But there is always just one entry in /proc/asound/cards
pi@raspberrypi:~ $ cat /proc/asound/cards
 0 [memsmic        ]: mems-mic - mems-mic
                      mems-mic
depending on the order the dtoverlays are loaded.
So I wonder how to tell Raspi to allow both sound devices at the same time.
It looks as if both devices are loaded as card 0.
Mixing 2 soundcards should be quite simple according to this description - if the two sound cards get registered by Pi:
https://bbs.archlinux.org/viewtopic.php?id=125913
Maybe I should open a new topic since this is no longer a mic problem ;)
Hello there,
I'm facing exactly the same problem mentioned above.
I can only either define my speaker's dtoverlay or the mic's dtoverlay, but not both.
Has someone found a solution to that issue? How to set a new, combined overlay for both?
Thanks.
gregeric
Mon May 15, 2017 9:13 pm
Google's Voice HAT (ICS43432 mics + MAX98357 DAC) ignores the ICS43432 codec & employs its own machine & codec drivers.
Maybe you could use that as a template, but it would be nice to figure out how to use simple-audio-card & device tree in lieu.
nicoq
Wed May 31, 2017 11:29 pm
For those who want to use I2S both in Capture and Playback, you'll find everything you need there:
viewtopic.php?p=1001577#p1001577
I tried it with a SPH0645 microphone and JusBoom Hat on Rpi Zero W and all is working !
tmratwork
unable to boost record volume
Sun Dec 10, 2017 7:18 am
i can record in stereo with the following command:
arecord -Dhw:1 -c2 -r48000 -fS32_LE -twav -d10 -Vstereo test.wav
i followed the tutorial to boost (control) recording volume by updating the .asoundrc file.
when i run the following command, nothing records. same mics, same wiring. command above records static plus my voice. command below records static only.
$ arecord -Dmic_sv -c2 -r48000 -fS32_LE -twav -d10 -Vstereo test2.wav
Recording WAVE 'test2.wav' : Signed 32 bit Little Endian, Rate 48000 Hz, Stereo
pi@raspberrypi:~ $
any ideas?
my .asoundrc file:
pcm.!default {
        type hw
        card 0
ctl.!default {
        type hw
        card 0
pcm.mic_hw{
        type hw
        card memsmic
        channels 2
        format S32_LE
pcm.mic_mm{
        type mmap_emul
pcm.mic_hw{
        type hw
        card memsmic
        channels 2
        format S32_LE
pcm.mic_mm{
        type mmap_emul
        slave.pcm mic_hw
pcm.mic_rt{
        type route
        slave.pcm mic_mm
        ttable.0.0 1
        ttable.0.1 0
        ttable.1.0 1
        ttable.1.1 0
in audacity, mic_hw records, but audacity will not start recording if i select mic_mm, mic_rt, or mic_sv.
tmratwork
boosting record volume
Mon Dec 25, 2017 10:14 pm
i updated .asoundrc to include:
pcm.mic_hw{
	type hw
	card memsmic
	channels 2
	format S32_LE
pcm.mic_mm{
	type mmap_emul
	slave.pcm mic_hw
pcm.mic_sv{
	type softvol
	slave.pcm mic_mm
	control {
		name "Boost Capture Volume"
		card memsmic
	min_dB -3.0
	max_dB 50.0
pcm.mic_mono{
	type multi
	slaves.a.pcm mic_sv
	slaves.a.channels 2
	bindings.0.slave.a
	bindings.a.channel 0
then i activated the mixer:
arecord -Dmic_sv -c2 -r48000 -fS32_LE -twav -d10 -Vstereo test.wav
but when i record using -Dmic_sv nothing records. when i record using -Dhw the stereo recording works, but record volume very low.
any hints? has something changed to break the previous way of boosting mems mic record volume?
Who is online
Users browsing this forum: No registered users and 15 guests
