I admit I didn't know where else to put this, so this seemed appropriate.
In all the pin-out descriptions and tables I have seen, from the first Pi to the most recent (except, of course the Compute Modules), the pins are numbered "incorrectly", which has only just dawned on me while I was trying to layout a PCB using Fritzing.
Conventionally, for an IC or other connector, if it is oriented "correctly", pin#1 is top left, and the numbers increase going down the left side, and increase coming back up on the right.
If for example, you look at the specification for the MCP23008, you can see just this.
However, for the Pi, whether it's a 26 pin or 40 pin header, they go from left to right, then down to the left and right again, and so on.
Now, I recognise that this means that the pin numbering for the 26 pin version and the matching pins on the 40 pin version is the same, which is useful. But it does mean that there is a bit of a mental shift needed when designing a PCB to connect to the Pi, since what is referred to as pin#2 on the Pi (5V) is different to pin#2 on the connector (I2C#1 SDA).
If you had only a list of pin assignments, not a diagram, this could cause much cursing and gnashing of teeth, particularly if you put 5V through the I2C pin.
Of course, the answer is that if you're designing your own PCB, you should double check these things anyway, but out of interest, why was it done this way, against normal convention?
(I know - if it took me 5 years to notice, why am I complaining about it? No, I didn't blow anything up, but it did add an extra layer of "thinking" about the board layout...)
Pin numbering
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
- DougieLawson
- Contact: Website Twitter
Re: Pin numbering
Eh?
http://pinout.xyz and all the Fritzing stuff appears to be zig-zag numbering and 100% correct to me.
http://electronics.stackexchange.com/qu ... ng-schemes
Re: Pin numbering
I thought the error was meant to be that pin 1 should be on the outer edge of the PCB, not the inner.
- DougieLawson
Re: Pin numbering
It's numbered for the conductors in an IDC cable.
http://connector.pinoutguide.com/10_pin_IDC_male/
Re: Pin numbering
Not if you compare the numbering scheme to any common IC. For those, the actual physical pin numbers run 1-20 on the left side, and 21-40 (going upwards) on the right side, whereas in the diagrams on the site, they go row-wise, not column-wise.
I'm not saying the pin descriptions are wrong, just that they are not numbered conventionally.
Don't know about the fritzing parts for the Pi, since I use headers only. Having just looked at it a few minutes ago, I now see what you mean. That will save me some work after all - I did wonder how the Pi components mapped through to the PCB layer, and now I know (and feel suitably enlightened and embarrassed in equal measure).
Steve S
Re: Pin numbering
Thanks Dougie, I now see what you mean, and in the context of the Pi that makes perfect sense - and of course it also means that 40->26 "downgrade" cabling will work perfectly well.
I will go and sit on my hands now, and use my brain instead.
Steve S
- FTrevorGowen
- Forum Moderator
- Contact: Website
Re: Pin numbering
And, just for confirmation (as performed many moons agoSteveSpencer wrote:Thanks Dougie, I now see what you mean, and in the context of the Pi that makes perfect sense - and of course it also means that 40->26 "downgrade" cabling will work perfectly well.
http://www.cpmspectrepi.uk/raspberry_pi ... -pin_cable
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Re: Pin numbering
My understanding is that conventional numbering is different for ICs than it is for pin headers. https://en.m.wikipedia.org/wiki/Pin_header
