Magimedia
Can I use an NRF24L01+ and a TouchScreen with Pi Zero?
Thu Sep 15, 2016 7:48 pm
I've never used the NRF24L01+ module before, and I want to use it to communicate with some PIC controlled lighting. I also want to use the Pi with a touchscreen. Both need the MOSI/MISO pins - does that essentially mean it's on or the other, but not both?
scotty101
Re: Can I use an NRF24L01+ and a TouchScreen with Pi Zero?
Thu Sep 15, 2016 8:09 pm
Multiple SPI devices can be connected, you just need to connect each to a separate Chip Select line.
Magimedia
Thu Sep 15, 2016 8:20 pm
Thanks.
So I connect the MOSI/MISO/SCLK in parallel, and since my touchscreen is using CE1 on the GPIO header, and can't be changed, I need to simply recompile a library for the NRF24L01+ that uses CE0?
(I say simply, it looks daunting, but I'm determined!)
scotty101
Fri Sep 16, 2016 11:35 am
It might be that simple. Depending on the NRF24L01 library you might just be able to tell it to look at a different device on the same port.
For example python-spidev the syntax is
spi.open(bus, device)
Which will open the spidevice /dev/spidev<bus>.<device>
