arlen22
I2C based RS-485 master board
Sat Jul 30, 2016 10:20 pm
I want to use RS-485 to transmit over several hundred feet, and I am wondering if there is an I2C based RS-485 master board available anywhere. In other words, I want a daughterboard/hat/whatever that connects to the I2C bus on the RaspberryPi. It doesn't have to be a transparent repeater.
Re: I2C based RS-485 master board
Sun Jul 31, 2016 5:57 am
arlen22
Mon Aug 01, 2016 10:58 am
Aha!! Perfect! Thank-you. I knew there had to be one somewhere.
TonyD
Mon Aug 01, 2016 12:21 pm
Here's another RS485 module that's designed to work with the Pi:
https://www.tindie.com/products/DTronix ... -on-board/
Tony
stderr
Tue Aug 09, 2016 4:41 am
arlen22 wrote:Aha!! Perfect! Thank-you. I knew there had to be one somewhere.
So you are looking for RS-485 on the pi? I thought you meant you wanted to connect something with an I2C interface to RS-485 and then to the pi. Basically:
pi--->---RS-485 +++++++ RS-485--->---I2C
Seems you are more looking for the left side of this than the right. But is I2C actually involved, is the right side relevant to your application?
