ir_fuel
Can't get I2C to work correctly
Sun Jul 24, 2016 12:07 am
Hi
I have a Raspberry Pi rev3 board, installed NOOBS and have everything configured to use I2C.
I connected an Adafruit 10DOF board (which is an LSM303 combined with a few other sensors) and I want to read the accelerometer values.
I have tried different languages (nodejs, C), but I think it's easier to show what's going on by simply using terminal commands.
When running
i2cdetect -y 1
I can see that the board is correctly connected:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- 19 -- -- -- -- 1e --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- 6b -- -- -- --
70: -- -- -- -- -- -- -- 77
However when trying to read or write I always get errors:
i2cget -y 1 0x19 0x20
Error: Read failed
i2cset -y 1 0x19 0x20 0x27
Error: Write failed
Running those commands with sudo has the same effect
ls -l /dev/i2c-1
crw-rw-rw- 1 root i2c 89, 1 Jul 23 23:40 /dev/i2c-1
Any idea on how I can debug this?
Re: Can't get I2C to work correctly
Sun Jul 24, 2016 5:03 pm
ir_fuel
Sun Jul 24, 2016 10:45 pm
Well, I can't just use that since it depends on Arduino libraries.
I did look into the code to see how they do things, but I think my test cases on the command line show the problem is somewhere else imho.
Just to add: i2cdump also works
i2cdump -y 1 0x19
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
10: XX XX XX XX XX XX XX 7f 25 03 71 64 e7 XX XX XX    XXXXXXX?%?qd?XXX
20: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
30: XX XX XX XX XX XX ff XX XX XX XX XX XX XX XX XX    XXXXXX.XXXXXXXXX
40: XX XX XX XX XX XX XX XX 00 0f 00 03 3f 00 00 01    XXXXXXXX.?.??..?
50: 00 00 07 XX 00 00 00 00 00 00 00 00 00 00 00 00    ..?X............
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33    ...............3
90: 93 03 8c 22 01 32 e4 a4 24 03 70 64 e0 20 80 00    ???"?2??$?pd? ?.
a0: 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20    ?..............
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
christian-nils
Wed Jul 27, 2016 6:34 am
Hello!
A linux driver for ST accelerometers exists (https://github.com/raspberrypi/linux/bl ... ccel_i2c.c)
You just have to enable the driver by recompiling the kernel.
Then you should bind the hardware (For the binding, I guess you can have a look to https://github.com/raspberrypi/linux/bl ... lis302.txt which should be similar for the lsm303). It will automatically appears in /sys/bus/iio/devices/ afterwards.
You can then use libiio to write your code to access the hardware.
It should be something similar with the other sensors on the breakout board.
/CN
tsaG
Thu Jul 28, 2016 12:26 am
Do you have an Oscilloscope? Try to hook it up to (at least) the SCK Line. I had this problem before. After doing several i2cget and i2cset the lines were always low and I had to powercycle (not only reboot) the Pi.
christian-nils
Thu Jul 28, 2016 5:49 am
tsaG and I had a problem with the i2c baudrate. You can try increasing the baudrate to something like 1Mbps to see if the accelerometer replies.
/CN
