doyle
Re: WebIOPi : control your Pi’s GPIO with a browser
Tue Dec 17, 2013 7:56 am
trouch wrote:As it's noticed on the project page, you are welcome to use WebIOPi in the way you want !
- all bundled
- only the REST API
- though the javascript API...
check upcoming modifications on WebIOPi 0.5, you may found it use full for you !
trouch can you be a bit clear i am totally new to this
pyromagi
Fri Dec 27, 2013 12:11 pm
I have managed to make a small index.html with 2x8 on/off buttons that works great.
but i would like to add a button that sets all other buttons (gpio pins) to "High", how do i do that?
Kind Regards
Fri Dec 27, 2013 12:13 pm
pyromagi wrote:Hi,
Kind Regards
Post your HTML here.
The answer is probably javascript to toggle the values of all of the buttons before submitting the CGI form.
pyromagi
Fri Dec 27, 2013 12:17 pm
Index.html
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
 <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
 <title>WebIOPi | Light Control</title>
 <link href="style.css" id="stylesheet" rel="stylesheet" type="text/css" />
 <script type="text/javascript" src="/webiopi.js"></script>
 <script type="text/javascript" src="buttons.js"></script>
</head>
<body>
        <table border="1">
                <tr>
                        <td id="cell1">
                        </td>
                        <td id="cell2">
                        </td>
                </tr>
                <tr>
                        <td id="cell3">
                        </td>
                        <td id="cell4">
                        </td>
                </tr>
                <tr>
                        <td id="cell5">
                        </td>
                        <td id="cell6">
                        </td>
                </tr>
                <tr>
                        <td id="cell7">
                        </td>
                        <td id="cell8">
                        </td>
                </tr>
        </table>
</body>
</html>
buttons.js
webiopi().ready(function() {
        button = webiopi().createGPIOButton(2,"Que 1");
        $("#cell1").append(button);
        button = webiopi().createGPIOButton(3,"Que 2");
        $("#cell2").append(button);
        button = webiopi().createGPIOButton(4,"Que 3");
        $("#cell3").append(button);
        button = webiopi().createGPIOButton(17,"Que 4");
        $("#cell4").append(button);
        // auto refresh UI
        webiopi().refreshGPIO(true);
Fri Dec 27, 2013 1:13 pm
Is there a python script with that?
pyromagi
Fri Dec 27, 2013 8:14 pm
Not that I'm aware of.
I have not made any myself, so the SCRIPTS section of /etc/webiopi/config is default.
Kind Regards
Fri Dec 27, 2013 9:26 pm
pyromagi wrote:Not that I'm aware of.
Kind Regards
I that case I can't help because I don't know how you've got your original code to work.
pyromagi
Fri Dec 27, 2013 9:39 pm
My guess is that I'm using the REST API, i have more or less done what the basic tutorial on the webiopi site is showing.
Would be nice with a "reset all pins (to high/low) button" :D
Kind Regards
xyboox
Wed Jan 01, 2014 3:18 pm
Hi guys,
so I'm trying to make a small simple app to control the GPIO of my Pi using webiopi REST API. I want to use this because I need a client side as html5 ( to be packed as an Android/iOS app using phonegap ). All works great, untill I try to make AJAX POST calls to the API and then I get this problem with crossdomain requests policy. Error is "No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://some-domain-here.com' is therefore not allowed access. " Is there a way to make these POST requests from another domain?
Thanks!
Phenom55
Tue Jan 28, 2014 2:59 am
Does anyone know if I can connect to my RPi with Mosync using WebIOPi http requests?
tafelrunde
Tue Apr 01, 2014 9:02 pm
I came over this thread recently.
@xyboox: did you whitlisted the domain you want to access?
greetings
jneha
Fri Jun 13, 2014 7:54 am
I am trying to run the Simple LED program through web(https://code.google.com/p/webiopi/wiki/Tutorial_Basis )
I am unable to create a GPIO button through webiopi using the function:
webiopi.createGPIOButton(17, "string");
Although the html page executes the python script fine, yet I am unable to view the GPIO button. Is it something related with the webiopi javascript file(webiopi.js)? Please help
wallarug
Wed Sep 03, 2014 11:17 am
Hey guys,
I can't get slider control to work in Google Chrome or anything else.
I press the slider, the light flickers on for a fraction of a second, then turns off.
Can someone help me?
Code:
<html>
<head>
        <meta name="viewport" content = "height = device-height, width = 420, user-scalable = no" />
        <title>Hot Box Control</title>
	 <script type="text/javascript" src="/jquery-1.11.1.min.js"></script>
	 <script type="text/javascript" src="/jquery.mobile-1.4.3.min.js"></script>
	 <link rel="stylesheet" href="/jquery.mobile.icons.min.css" />
	 <link rel="stylesheet" href="/jquery.mobile.structure-1.4.3.min.css" />
	 <link rel="stylesheet" href="/jquery.mobile-1.4.3.min.css" />
        <script type="text/javascript">
       var current = "off";
                var content, button, contentA, masters;
                contentA = $("#contentA");
		  content = $("#content");
		  masters = $("#masters");
//webiopi().updateFunction(4,"PWM");
//webiopi().enablePWM(4);
//alert(webiopi().getFunction(4));
		// Gertboard Buffers Section --> GPIOs 2,3,4,7,8,9,10,11 and 22,23,24,25
		// create a "SWITCH" labeled button for Buffer
                button = webiopi().createGPIOButton(2, "GPIO 2");
                contentA.append(button); // append button to content div
                button = webiopi().createGPIOButton(3, "GPIO 3");
                button = webiopi().createGPIOButton(4, "GPIO 4");
                button = webiopi().createGPIOButton(7, "GPIO 7");
                button = webiopi().createGPIOButton(8, "GPIO 8");
                button = webiopi().createGPIOButton(9, "GPIO 9");
                button = webiopi().createGPIOButton(10, "GPIO 10");
                button = webiopi().createGPIOButton(11, "GPIO 11");
                button = webiopi().createGPIOButton(22, "GPIO 22");
                button = webiopi().createGPIOButton(23, "GPIO 23");
                button = webiopi().createGPIOButton(24, "GPIO 24");
                button = webiopi().createGPIOButton(25, "GPIO 25");
		// MASTER SWITCHES ----
		// Button HOLD MASTER
		  button = webiopi().createButton("hold", "HOLD_ALL", mousedownMaster, mouseupMaster);
		  masters.append(button);
		// Button MASTER ON/OFF
		  button = webiopi().createButton("onoff","ON_OFF", onoffMaster);
		// HOT BOX CENTRAL CONTROL / LAYOUT
                // create a "LED" labelled button for GPIO 7
                button = webiopi().createGPIOButton(7, "LED");
                content.append(button); // append button to content div
                // create a button that output a single pulse
                button = webiopi().createPulseButton("pulse", "Pulse", 7);
                // create a button which output a bit sequence on GPIO 7 with a 100ms period
                button = webiopi().createSequenceButton("sos", "S.O.S 1", 7, 100, "01010100110011001100101010");
                // the previous button will always output the same sequence
                // you can also create a simple button with your own function
                button = webiopi().createButton("sos2", "S.O.S 2", outputSequence);
                // you can also create a button which calls a different function for mouse down and up events
                //button = webiopi().createButton("hold", "Hold", mousedown, mouseup);
                //content.append(button);
                // Only for Chrome and Safari, create a slider that pulse out a 0-100% duty cycle ratio on GPIO 8
                button = webiopi().createRatioSlider(4);
		  webiopi().pulseRatio(4,0.5);
                // Only for Chrome and Safari, create a slider that pulse out a -45 to +45° angle on GPIO 9
                button = webiopi().createAngleSlider(9);
	function mousedownMaster() {
              webiopi().digitalWrite(2, 1);
              webiopi().digitalWrite(3, 1);
              webiopi().digitalWrite(4, 1);
              webiopi().digitalWrite(7, 1);
              webiopi().digitalWrite(8, 1);
              webiopi().digitalWrite(9, 1);
              webiopi().digitalWrite(10, 1);
              webiopi().digitalWrite(11, 1);
              webiopi().digitalWrite(22, 1);
              webiopi().digitalWrite(23, 1);
              webiopi().digitalWrite(24, 1);
              webiopi().digitalWrite(25, 1);
        function mouseupMaster() {
              webiopi().digitalWrite(2, 0);
              webiopi().digitalWrite(3, 0);
              webiopi().digitalWrite(4, 0);
              webiopi().digitalWrite(7, 0);
              webiopi().digitalWrite(8, 0);
              webiopi().digitalWrite(9, 0);
              webiopi().digitalWrite(10, 0);
              webiopi().digitalWrite(11, 0);
              webiopi().digitalWrite(22, 0);
              webiopi().digitalWrite(23, 0);
              webiopi().digitalWrite(24, 0);
              webiopi().digitalWrite(25, 0);
	function onoffMaster() {
              if(current=="off"){
		current = "on";
		}else{
		current = "off";
        function outputSequence() {
                var sequence = "01010100110011001100101010" // S.O.S. morse code or whatever you want
                // output sequence on gpio 7 with a 100ms period
                webiopi().outputSequence(7, 100, sequence, sequenceCallback);
        function sequenceCallback(gpio, data) {
                alert("sequence on " + gpio + " finished with " + data);
        function callMacro() {
                var args = [4,2,3] // or whatever you want
                // call myMacroWithArgs(arg)
                webiopi().callMacro("myMacroWithArgs", args, macroCallback);
        function macroCallback(macro, args, data) {
                alert(macro + " returned with " + data);
        </script>
        <style type="text/css">
                button {
                        display: block;
                        margin: 5px 5px 5px 5px;
                        width: 160px;
                        height: 45px;
                        font-size: 16pt;
                        font-weight: bold;
                        color: black;
                custom_button {
                        display: block;
                        width: 160px;
                        height: 45px;
                        font-size: 24pt;
                        font-weight: bold;
                        color: black;
                input[type="range"] {
                        display: block;
                        width: 160px;
                        height: 45px;
                #gpio2.LOW {
                        background-color: White;
                #gpio2.HIGH {
                        background-color: Red;
                #gpio3.LOW {
                #gpio3.HIGH {
                #gpio4.LOW {
                #gpio4.HIGH {
                #gpio7.LOW {
                #gpio7.HIGH {
                #gpio8.LOW {
                #gpio8.HIGH {
                #gpio9.LOW {
                #gpio9.HIGH {
                #gpio10.LOW {
                #gpio10.HIGH {
                #gpio11.LOW {
                #gpio11.HIGH {
                #gpio22.LOW {
                #gpio22.HIGH {
                #gpio23.LOW {
                #gpio23.HIGH {
                #gpio24.LOW {
                #gpio24.HIGH {
                #gpio25.LOW {
                #gpio25.HIGH {
        </style>
</head>
<body>
  <div data-role="page" id='home' data-theme='a' data-content='a'>
    <div data-role="header" data-theme="a">
      <h1>Hot Box Central Control</h1>
   </div>
    <div data-role="content">
        <div class='ui-grid-b'>
           <div class='ui-block-a' style='text-align:center;'>
		<div data-role='header' data-theme='b'><h2> Gertboard Buffers </h2></div>
		<br />
		<table>
		<tr><th>Overrides</th><th>MASTERS</th></tr>
		<tr>
		<td><div id="contentA" align="center"></div></td>
		<td><div id="masters" align="center"></div></td>
		</tr>
		</table>
	    </div>
	    <div class='ui-block-b'>
		<div id="HotBox"></div>
	    </div>
	    <div class='ui-block-c'>
		<div id="content" align="center"></div>
	    </div>
    </div>
    <!-- /content -->
</body>
</html>
wallarug
Sat Sep 06, 2014 12:09 pm
Guys,
I am still having the same problem? Can someone please help?
Started a thread with all the code: http://www.raspberrypi.org/forums/viewt ... 76#p608576
srahmati
Thu Dec 11, 2014 9:21 am
Hi I downloaded webiopi-0.5.3 from google code and installed it.my pi is connected to my laptop and share wifi over it.my webiopi runs successfully in the terminal.but I can access to it just with my laptop that it is connected to it.cant access with my HTC one or other laptop browser.any suggestions?
KnightOfPi
Thu Jul 23, 2015 9:48 am
Cancelor wrote:I've got WebIOPi working, no problem, but I want to integrate a DHT11 humidity sensor. Can this be done by a novice with no programming skills?
Yes, with the Adafruit_DHT driver updated for python3:
http://www.knight-of-pi.org/measure-tem ... 22-am2302/
Check out www.knight-of-pi.org for many beginner-friendly tutorials!
restomaguio
Sat May 21, 2016 11:26 am
Your work is really great! I have done many modifications on the menu apps side by forcing myself to learn html, java and css scripts. I have now several modified buttons and background (green PCB layout) I preferred. It was entirely different from your six buttons example. Many many thanks for your detailed unselfish guides and honest instructions. It works fine upon boot on Raspberry Pi Model B and I am controlling now my modified Stryder Robot using my smartphone or laptop.
I hope you upgrade it in order to work for Pi 2. Even the Filezilla was not connecting and can't find the server.
Thanks very much again for your marvelous and great contribution to Raspberry Pi communities.
Rolly
chaoliang.yi
Mon Dec 16, 2019 11:47 pm
I am trying to set it up to run on PI 4B with Python 2.7.16. But it popped up some errors on the source code.
Just would like to know whether WebIOPi has been updated to support PI 4B?
I saw the latest update is in 2015.
Regards
Chao
Wed Dec 18, 2019 4:09 am
Regards
Chao
I wouldn't touch WebIOPi with a forty foot barge pole.
Judging by http://webiopi.trouch.com/ I think it really is dead and buried now.
