Aholmes28191
Please help? USB and connector
Wed Jun 22, 2016 8:39 pm
Hi guys I've installed perl pobd recorder on to my pi and if I use
./pobd_logger -v /dev/pts/ttyUSB0
It connected to the odb connector and gives all the information
But this software is suppose to be designed to work headless and when I connect to a car as per the instruction it lights up the one connected but doesn't appear to be logging, the ACT light should be constant green to indicate logging but seems to load the OS and the ACT light goes out
Can some one please help really stuck
quinness
Re: Please help? USB and connector
Mon Jun 27, 2016 12:41 pm
May it be that there is some ground loop? (if not tested yet?) can you run your Rasp from some power not connected to the car? Like a power bank for mobile phones or similar, not att all in contact with the car, except through the odb.
Raspian Jessie 2016-02-26 _-=* If there are choices, why complain? *=-_
openSUSE LEAP 42.1 (3 pcs) _-=* Uppland, Sweden *=-_
