Magimedia
I2C and Logic Level shift, or different FETs?
Mon Jun 20, 2016 6:15 pm
I've got one of the 16 channel PWM modules that I intend to control RGB strips with. I'm not sure on the current draw per strip, but I think it's around 600mA per channel.
I have some IRL520N MOSFET that I have used before to control the strips... but that was on a 5V system, and the Pi I2C is 3.3V
This leaves me with a dilemma... would it be better to use a logic-level shift and move the I2C up to 5V, or should I replace the FETs with something that has a lower Vgs? The logic level shift seems to be the cheaper option, but do they work with I2C ok? I know they say they do on the eBay listings, but that's always to be taken with a pinch of salt...
mahjongg
Re: I2C and Logic Level shift, or different FETs?
Mon Jun 20, 2016 6:37 pm
If you use the level shifters Philips invented for I2C then they will work fine
FTrevorGowen
Mon Jun 20, 2016 7:00 pm
FWIW, I've tried the level-shifting modules linked-to below - some of which are (marketed as) I2C safe. There are further links to circuit schematics etc. for the uses I've put them to within that webpage.
https://www.cpmspectrepi.uk/raspberry_p ... dules.html
Trev.
Magimedia
Tue Jun 21, 2016 12:59 am
Thanks - I got a generic level shifter (looks like your D, but came from eBay) - seems to be working ok with I2C as I can use the clock module ok as a test.
