Sorry for taking too long to answer, I thought since this was my post I would automatically receive
an email if anyone replied
Anyway, these are my system specs
.~~. .~~. Wednesday, 27 April 2016, 10:43:36 pm UTC
'. \ ' ' / .' Linux 4.1.19-v7+ armv7l GNU/Linux
: .~.'~'.~. : Filesystem Size Used Avail Use% Mounted on
~ ( ) ( ) ~ /dev/root 30G 5.7G 23G 21% /
( : '~'.~.'~' : ) Uptime.............: 0 days, 00h01m51s
~ .~ ~. ~ Memory.............: 610672kB (Free) / 753132kB (Total)
( | | ) Running Processes..: 104
'~ ~' IP Address.........: 192.168.0.104
*--~-~--* Temperature........: CPU: 45°C/113°F GPU: 45°C/113°F
The RetroPie Project, http://www.petrockblock.com
So, as you can see I'm using Retropie and my Kernel is 4.1.19. Could it be the kernel version?
This is my config.txt right now
(Added your line and it still won't work)
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
avoid_warnings=1
arm_freq=1350
core_freq=500
sdram_freq=500
over_voltage=4
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtoverlay=pi3-act-led,gpio=26
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
gpu_mem_256=128
gpu_mem_512=256
gpu_mem_1024=256
overscan_scale=1
The act LED IS disabled on the board, it won't blink unless I cut out that line, but my LED won't turn on, blink or whatevs.
It is wired to the ground and 26 pin (The last one of the rows), and the wire that comes out of the 26 pin, has a 65ohm resistor to it and then it's connected to the LED positive leg. As I mentioned before, it does work on my external Power Supply, the resistor is right for the 3.3v output of the pin.
And it returns the following...:
pi@retropie:/home/pi# ls /boot/overlays/pi3-act-led*
/boot/overlays/pi3-act-led.dtb /boot/overlays/pi3-act-led-overlay.dtb
/boot/overlays/pi3-act-led.dtbo
