ron47
Can’t see anything on the I2C [solved]
Tue Apr 05, 2016 7:11 am
Hello Forum,
I need your Help.
I want to readout sensors via an I2C-bus. To do this have I inserted a TC74 (A0-5V) and a BMP180 on a test board together. I’m using Debian Wheezy.
lsmod produces the following results:
i2c_dev                 5620  0
i2c_bcm2708             3759  0
snd_bcm2835            15846  0
snd_pcm                77560  1 snd_bcm2835
snd_seq                53329  0
snd_timer              19998  2 snd_pcm,snd_seq
snd_seq_device          6438  1 snd_seq
snd                    58447  5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
snd_page_alloc          5145  1 snd_pcm
leds_gpio               2235  0
led_class               3562  1 leds_gpio
joydev                  9316  0
evdev                   9426  3
i2cdetect -y 1 shows the following:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I’m logged in as root!
The modules are supplied with 3, 3V. I have test the circuit even with two 4.7 K ohm pull-up resistors, unfortunately with the same result. Can someone please give me a hind?
Thanks Ron
ron47
Solved: Can’t see any ting on the I2C
Tue Apr 05, 2016 10:15 am
Sorry, one wire was broken between the RasPi and the test board. After replacement, It's working fine.
