quinness
I2C device change address after init
Sat Mar 26, 2016 12:50 pm
Hello and happy Easter (to whom it concerns).
When my Rasp B+ start, my LIS302DL accelerometer has address 0x40, but one second later when run i2cdetect again, it has the address as stated in data sheet, 0x1c. The other device with 0x48 is a DS1621 with no problem. Have anyone else had similar problem or a solution to the problem.
pi@raspberrypi:~/Develop/Python/LIS302DL $ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: 40 -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- 1c -- -- --
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
Raspian Jessie 2016-02-26 _-=* If there are choices, why complain? *=-_
openSUSE LEAP 42.1 (3 pcs) _-=* Uppland, Sweden *=-_
joan
Re: I2C device change address after init
Sat Mar 26, 2016 1:22 pm
Changing addresses is often a symptom of loose wiring,
