JohnBeardmore
wiringPi on Pi 3 Model B
Wed Mar 23, 2016 3:19 pm
Is wiringPi reay for the Pi Pi 3 Model B yet ?
Many thanks, J/.
Author of oBeMS open source Building energy Management System.
Automatic Meter Reading (AMR), Building Management System (BMS),
Building Energy Management System (BEMS), Infrastructure Control System (ICS).
See: http://t4sustainability.co.uk/oBeMS/
DirkS
Re: wiringPi on Pi 3 Model B
Wed Mar 23, 2016 5:04 pm
Does it need a change?
JohnBeardmore
Wed Mar 23, 2016 10:21 pm
:) If I knew I wouldn't be asking.
I understand that that the Pi 2 and Pi 3 boards have pretty similar layouts, but I've no idea if there are any changes in the chipset or timings which might require changes to wiPi.
I'd quite like to try a Pi 3, if only for the built in WiFi, but I'll stick with Pi 2 for now if wiringPi isn't available for it yet.
Cheers, J/.
DirkS
Wed Mar 23, 2016 10:58 pm
The way you asked the question implied that it would need changing...
AFAIK wiringpi works on both Pi2 and Pi3
JohnBeardmore
Wed Mar 23, 2016 11:19 pm
I don't know how similar the Pi2 and Pi3 chipsets are, but even if one is only a faster version of the other I suppose there could be issues, so it seemed worth asking if it was ready / tested / known to work.
Anyway, given that it does, I'll get a Pi3 and give it a go.
Cheers, J/.
mattn152sm
Thu May 05, 2016 3:22 am
I just added wiringpi to my PI3 (sudo apt-get install wiringpi) running Jessie-Lite 2016-03-18, and it works.
kolban
Thu May 05, 2016 5:40 pm
I too have been using wiringPi on the Pi3 without issue.
FREE book on Raspberry Pi usage and programming
https://leanpub.com/pi
