Page 5 of 7
Re: [quick-guide] CAN bus on raspberry pi with MCP2515
Posted: Sun Feb 12, 2017 8:52 pm
by samirFSR
can we add more nodes as we want?
Posted: Mon Feb 13, 2017 9:22 pm
by saper_2
samirFSR wrote:Hi,
Hi.
samirFSR wrote: can we add more nodes as we want?
Excuse me, what nodes?!
CAN-BUS is multi-node bus so there can be connected more than 2 nodes, just remember about terminating resistors (circa 120R ?) at end nodes - the devices that are the most apart from each other.
Posted: Mon Apr 10, 2017 5:26 pm
by Leseratte10
I bought the exact same module mentioned in the first post. However I don't quite understand how I can make the power supply work. The one trace on the back of the board is used to provide the second, smaller chip with +5V, right?
That would mean I'd just need to cut that trace and provide power to the second chip myself and it would work. However, in the pictures in the first post it looks like the 5V power has just been soldered on top of the trace, in addition to the 3.3V already there?
Or can we cut the trace, then scrape off some of the protective blue stuff on the board to expose the metal, and *then* solder 5V to the trace? If yes, on which side? I guess it's the left side when I look at the bottom of the board with the CAN connector left, is that correct?
Posted: Thu Apr 20, 2017 8:19 pm
by saper_2
HI,
Sorry for late answer -_-
The trace is cut, in this image you see there is a part of trace removed: http://postimg.org/image/wqile3twv/
Verify with schematic how it should be done - photos are just for reference.
Posted: Fri Apr 28, 2017 8:44 am
by wiebel
Thank you very much. I would have spent ages debugging the 5V transmitter issue. Especially as I am using a perfectly fine 3V3 transmitter with the teensy for the rest of my nodes and simply assumed a compatible type on that module. That brings me to an other comment on your article. You're saying the transmitter needs 5V as CAN must be driven at 5V, which is not exactly true. While the actual transmitter on this popular MCP2514 module must be driven at 5V there are others. So it may be a valid option to simply swap the transmitter by a pin compatible type (which most are), eg. http://www.ti.com/product/SN65HVD232.
You can read about the interoperability between 5V and 3V3 transmitters here: https://e2e.ti.com/support/interface/in ... 2/t/230101
Posted: Wed May 03, 2017 3:27 pm
by leocat3
Hi All!
I continue to develop the idea of working with a can bus through an adapter USB-UART-CAN.
On Raspberry PI you can use UART-CAN adapter directly, witout USB-UART.
An introduction to what's done: http://open-plc.blogspot.ru/2016/12/ope ... logic.html
You can use up to 100 devices on the CAN bus.
Posted: Wed May 10, 2017 3:05 pm
by darkestday
> because CAN bus operates on 0V and 5V levels, lower high level is considered as noise/distortion (this is defined by CAN Bus specification).
No. you only need a difference between can high and low of 2.5v. There is absolutly no problem in mixing 3.3 and 5v in a bus.
The specification is by th way ISO 11898 . 3.3v Trancievers are ISO 11898 -2 compliant.
Posted: Fri May 12, 2017 9:39 am
by darkestday
On second thought - where do you have the schematics from? the MCP2515 runs from 2.7 to 5.5v...therefore it can be directly used with an 3.3 arm m0 (for example)
Posted: Mon May 15, 2017 7:47 am
by mIwav
Hi all,
has anyone of you experienced the following issue with a setup using the NiRen MCP2515_CAN with 8 MHz crystal in combination with a Raspberry Pi Zero W:
After modifying the circuit as described, I can set the usual CAN bus clock frequencies 125kHz, 250kHz and 500kHz and I can verify the operation using candump. Everything is fine
However when I try to set the bus frequency to 1MHz using the following command
sudo ip link set can0 up type can bitrate 1000000
I get the following response
RTNETLINK answers: Numerical argument out of domain
and dmesg shows
[   77.213639] mcp251x spi0.0 can0: bitrate error 33.3% too high
Has anyone seen this already? Could this be a bug, an issue with the circuit or a SPI issue?
Posted: Mon May 15, 2017 11:47 am
by leocat3
# uname -a
Linux buildroot 2.6.35.3-1129-g691c08a #529 PREEMPT Wed Mar 1 02:30:27 NOVT 2017 armv7l GNU/Linux
# /sbin/ip -d link sho dev can1
3: can1: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN qlen 10
link/can
can <TRIPLE-SAMPLING> state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
bitrate 1000000 sample-point 0.750
tq 83 prop-seg 4 phase-seg1 4 phase-seg2 3 sjw 1
flexcan: tseg1 4..16 tseg2 2..8 sjw 1..4 brp 1..256 brp-inc 1
clock 24000000
Posted: Mon May 15, 2017 12:05 pm
by leocat3
If on mcp2515 set quartz 8 MHz, then:
The desired CAN bus speed is not possible with the specified CAN clock frequency and tolerance.
May be 16 or 24 MHz.
On 8 MHz max = 500 KBit/Sec
Posted: Mon May 15, 2017 2:46 pm
by mIwav
Thank you very much leocat3!
I did not read the mcp2515 specs consciously enough, I'm sorry...
It is stated there that the theoretical minimum CAN bit time consists of 5 CAN time quanta (TQ). 1 TQ for Sync, 1 TQ for Propagation Segment, 2 TQ for Phase Segment 1 and 1 TQ for Phase Segment 2.
With an oscillator frequency of 8 MHz, the resulting TQ time is TQ = 2 * BRP / Fosc, with the Baud Rate Prescaler BRP.
Therefore the minimum time quantum at 8 MHz is 2 / 8 MHz = 250 ns. As five time quanta are needed the theoretical minimum bit time is 1250 ns resulting in a CAN bus bit frequency of 800 kHz.
Therefore I will try to replace the crystal by a higher value (i.e. 16 MHz and above). Thank you again!
Posted: Mon May 22, 2017 1:43 am
by mamuti
Hi
I hope you are still tracking this post; I had a stupid question: suppose I want to setup CAN interface with a baudrate like 125k, using the following command:
sudo ip link set can0 up type can bitrate 125000
Do I need to connect the mcp2515 and all the rest of network? or it is a software step?
Posted: Tue Jul 11, 2017 6:58 am
by toannt
Thank you very much for sharing, all your steps work properly in my case.
If anyone trying the system like: PI3 -- MCP2515---MCP2515---Arduino Uno, the following information would help.
1. Saper_2 was totally right on modifying the power supplying wires. because TJA1050 requires minimum 4.78V.
Instead of cutting the wire on board, you can just do like this: https://www.youtube.com/watch?v=_v3GumyXbhw
it is better to my welding skill. And just for sharing, I just picked up the VDD pin of MCP2515 and welded it to a line that I can supply 3.3V. Yeah follow fully the video will give you a very beautiful board thought, :D.
2. On Raspbian 4.1.18 and 4.9.35, every steps works fine. The difference thing in my case:
-On 4.1.18: when the INT was wrongly wired: "can0" appeared in "ifconfig can0" and even the first "cansend" successfully sent and received. Then later "cansend" was never received by other CAN module. My bad-luck that I'm just a software developer and there was typo on my new-bought Pi3 GPIO cable that label wrongly the GPIO 12 pin...
-On 4.9.35: when the INT was wrongly wired: "can0" could not be seen.
3. On Arduino: there are 2 points to be considered.
-INT pin must be wired to Arduino, usually to D2 but it may depends on the CAN lib.
(I stared with a guide that not use INT pin like this http://henrysbench.capnfatz.com/henrys- ... -tutorial/. if my feeling was correct, the INT pin at least used to check if data is available to be read. Anyway, this is a good post and I did not test the Arduino-Arduino case).
-Oscillator 8MHz is also the problem, because Arduino CAN libs usually configured to work with default 16MHz module. you can use this lib https://github.com/Flori1989/MCP2515_lib with a modification to It's example code: CAN0.begin(CAN_125KBPS, MCP_8MHz);
4. moreover, for QT user.
from QT5.8, there is CAN module and a CAN example.
following this link, https://wiki.qt.io/RaspberryPi2EGLFS, I've built QT5.9 successfully and run the CAN module successfully to test my hardware.
Posted: Sun Jul 23, 2017 1:04 am
by vnrgoli
I am using Raspi3 <----> Pican <---->ECUsim 2000 OBD simulator.
Not receiving any packets/response from ECUSim (tested good.) No errors from cansend or candump (please see below.)
Any suggestions?
[email protected]:~/python/pican2duo $ ifconfig
can1      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          UP RUNNING NOARP  MTU:16  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4825 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:10
          RX bytes:0 (0.0 B)  TX bytes:38600 (37.6 KiB)
I see no errors when I send a request in cansend:
cansend can1 7DF#02010C0000000000
candump displays the message without any returned value
[email protected]:~ $ candump can1
  can1  7DF   [8]  02 01 0C 00 00 00 00 00
The simulator is working fine (tested with Bluetooth ELM127 dongle)
CAN-H (OBDII pin 6), CAN-L(OBDII pin 14) and Chassis Ground (OBDII pin 4) from ECUSim's OBDII port are connected to Pican to their corresponding connectors.
CANbus on Pican are terminated with 120Ohm resistors.
Posted: Mon Jul 24, 2017 8:23 am
by ahmedawad
@vnrgoli, check the baud rate on the PiCAN adapter side is the same as the one configured in /etc/network/interfaces on the RPI.
I can well asure that following this post till the end and I had every thing working fine.
Posted: Mon Jul 24, 2017 11:17 pm
by vnrgoli
ahmedawad wrote:@vnrgoli, check the baud rate on the PiCAN adapter side is the same as the one configured in /etc/network/interfaces on the RPI.
It did not help. Below is the can entry in /etc/network/interfaces
auto can0
iface can0 can static
bitrate 500000
auto can1
iface can1 can static
bitrate 500000
I am using skpangs PiCan Duo http://skpang.co.uk/catalog/p ... -1480.html
Does it require a different bitrate? I don't see any such indication in their user docs. Their customer support is not helpful either.
Posted: Wed Jul 26, 2017 5:22 pm
by haseel
Hey, I am using raspberry pi 3 with MCP2515 for reading and sending CAN messages via SPI.I am following all the steps as specified above but I'm neither able to send nor read any CAN message.While using the candump and cansend command i don't receive any error but I'm not any getting any output also. How should i proceed now ???? :?
Posted: Wed Jul 26, 2017 7:54 pm
by saper_2
Might be:
  • you set wrong bitrate (different that is on the bus that you connect to)
  • No ground - without GND connected should work but... Personally I had problems without connecting GND of nodes.
Posted: Sun Sep 03, 2017 1:31 am
by iwl
I've just got out if I cansend a frame and it is not Acked it is retransmitted forever and the buffer fills until no more space available.
I've red somewhere switching the loopback on makes Nacks ignored, but messages are not send over the bus at all then.
Can I change this somehow? I've just wanted to send messages and get it logged with an elm327 at the other end, sniffing only, not acking.
iwl
Posted: Thu Oct 19, 2017 11:34 am
by pnb990
I was follow this tutorial successfully on Debian Jessie.
But with Debian Stretch I cannot find net folder in :
ls /sys/bus/spi/devices/spi0.0/
or
ls /sys/bus/spi/devices/spi0.1/
Someone I have same problem ? or any ides to test ?
Posted: Thu Oct 19, 2017 6:33 pm
by saper_2
or
Check connections.... If On deb 8.x works then on 9.1 should too....
Just tested:
I used in config only one line (without the 2nd with bcm2835) - seems works ok (dmesg ok, net/can0 driver loaded).
Why only first line? I'm just too lazy to type too much :lol:
Posted: Mon Nov 06, 2017 3:26 pm
by muekno
Hi I get can0 and MCP initialized, I can enter the send lien with no error. The only difference to you setup is I hab a 16MHz quartz, but I have changed the line in config.txt
dtoverlay=mcp2515-can0,oscilator=16000000,interrup=12
but I get
~# ip -d -s link  show dev can0
3: can0: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
    link/can  promiscuity 0
    can state BUS-OFF restart-ms 0
          bitrate 125000 sample-point 0.875
          tq 500 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
          mcp251x: tseg1 3..16 tseg2 2..8 sjw 1..4 brp 1..64 brp-inc 1
          clock 8000000
          re-started bus-errors arbit-lost error-warn error-pass bus-off
          0          0          0          1          1          1         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    RX: bytes  packets  errors  dropped overrun mcast
    0          0        0       0       0       0
    TX: bytes  packets  errors  dropped carrier collsns
    0
what tells me the 16Mhz clock is not accepted.
further question I think for my application I need a LISTENONLY Mode, how can I get this mode.
Thanks for any help
Rainer
Posted: Tue Nov 14, 2017 6:02 pm
by saper_2
... CUT ...
Hmmm, your overlay params syntax is bad :D
check again "carefully": https://github.com/raspberrypi/firmware ... t/overlays 8-)
I don't know about using can from userapp , but
candump
can "dump" everything that happening on CAN bus.
Posted: Thu Nov 30, 2017 6:38 pm
by galicin
I did patch the same MCP2515 PCB and using PiZero W.
candump and cansniffer works fine, but when I try cansend at 500000 speed I receive on the PC with USB CAN interface frame with some wrong bits.
Do you know what could be the reason? I see a lot of discussions about SPI latency ...
