zydis
Raspi and Pic i2c problem
Tue Mar 08, 2016 7:47 am
Hi, I am using raspi as master and pic18f67k22 as slave.
Here is my code to define i2c for pic.
#use i2c(SLAVE, sda=PIN_d5, scl=PIN_d6, address = 0x40)
when I use this command at raspi terminal, address of pic is shown half of 0x40.
pi@raspberrypi ~ $ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Then whenever I use "sudo i2cdetect -y 1" raspi return nothing.
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Do you have any idea about this problem?
brekee12
Re: Raspi and Pic i2c problem
Tue Mar 08, 2016 10:32 am
Probably it is only a "ghost" signal. Check your I2C pins I can remember other pins.
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
6by9
Tue Mar 08, 2016 10:59 am
I2C has an 8 bit slave address field. The top 7 bits are the device id, and the bottom bit is the read/write bit.
Some systems use the entire 8 bit value when referring to an address. Others (including Linux) only use the actual address bits.
It sounds like your PIC is taking 0x40 as the full 8 bit value, so Linux sees half of it when it has knocked off the bottom direction bit.
zydis
Tue Mar 08, 2016 1:48 pm
And also i2c address map on raspi is not permanent. After first search address of 0x20 is disapearing and "sudo i2cdetect -y 1" shows nothing.
6by9
Tue Mar 08, 2016 2:03 pm
zydis wrote:And also i2c address map on raspi is not permanent. After first search address of 0x20 is disapearing and "sudo i2cdetect -y 1" shows nothing.
I'm no expert on PICs, but typically you need to give it some data to send back on a read (which is what i2cdetect is using). Does it send anything if the transmit FIFO is empty? Quite possibly not.
andornot
Sun Jun 11, 2017 9:43 pm
It looks like you are using the CCS PICC compiler. In your #USE statement the address must be 2 x the address you wish it to be. If you want the address to be 0x40, you must enter 0x80 in the address field of the #USE like this:
#use i2c(SLAVE, sda=PIN_d5, scl=PIN_d6, address = 0x80)
