There were rumors of the standard SPI driver being updated to support more than the current limit of two via the use of arbitrary GPIO pins used for CS. Does anyone know if progress has been made ?
Cheers
- mikronauts
- Contact: Website
Re: Maximum SPI Devices
If you want to add your own SPI i/o expanders, see my article
http://www.mikronauts.com/raspberry-pi/ ... and-howto/
which allows eight SPI devices per chip select.
If you want more off-the-shelf SPI based boards (tft etc) even a new driver would not help, as the drivers for those devices would not be set up for additional (or expanded) chip selects.
GrubbyHalo wrote:There were rumors of the standard SPI driver being updated to support more than the current limit of two via the use of arbitrary GPIO pins used for CS. Does anyone know if progress has been made ?
Cheers
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
Assuming you use the Linux kernel:
If you add to the devicetree, then gpios 8, 7 and 22 will be used for CS 0,1 and 2. Add more until satisfied...
If you add
gpio-cs = <&gpio 8>, <&gpio 7>,<&gpio 22>;
Slightly sorry to hijack this question.msperl wrote:Assuming you use the Linux kernel:
If you addto the devicetree, then gpios 8, 7 and 22 will be used for CS 0,1 and 2. Add more until satisfied...Code: Select all
@msperl
Could you summarise the capabilities of the current spi_bcm2853 driver (i.e. arbitrary slave selects, interrupt driven, polling, DMA, auxiliary SPI device).
I don't think the auxiliary SPI is currently supported. If not, have you any feel for when it might be supported by the Pi Linux driver?
Hi Martin. This is what i was looking for. Thank youmsperl wrote:Assuming you use the Linux kernel:
this is a bare metal forum.
It was accepted into the next raspbian kernel (4.4.x)joan wrote:I don't think the auxiliary SPI is currently supported. If not, have you any feel for when it might be supported by the Pi Linux driver?
https://github.com/raspberrypi/linux/co ... b239b1fd1f
Thanks.fsr wrote:It was accepted into the next raspbian kernel (4.4.x)joan wrote:I don't think the auxiliary SPI is currently supported. If not, have you any feel for when it might be supported by the Pi Linux driver?
I'm running 4.4.4-v7+ #850 on a Pi3 so gave it a go.
I just added dtoverlay=spi1-3cs to /boot/config.txt.
Unfortunately it won't boot with that line. Do you know of any gotyas?
Hi Joan,
I too have the same problem with SPI1 aux on RBPi 3.
If I add "dtoverlay=spi1-3cs" to /boot/config.txt the RBPi3 won't boot.
I'm running 4.5.2-v7+ on a Pi3 so gave it a go.
Are you able to solve the problem ?
Thanks in advance,
Giovanni
Thanks in advance,
Giovanni
Not directly. My solution is to use my pigpio library which supports both SPI devices. See http://abyz.co.uk/rpi/pigpio/cif.html#spiOpengchirico wrote:Hi Joan,
Thanks in advance,
Giovanni
Hi Joan,
thanks for the information.
Best Regards,
Giovanni
Best Regards,
Giovanni
still a bare metal forum...
looks like there is a conflict between the Aux Uart (UART1) and Aux SPI (SPI1) on the PI3 B. Still looking into it but disabling the Bluetooth (and therefore reverting the Uart config back to PI1/2) seems to work around the issue.
viewtopic.php?f=29&t=146291&p=977167#p977167
@fsr Thanks.
Is the question 'how many chip selects can be defined' a pure numbers question?
There must be an electronic limit to what the SPI bus can drive.
I don't know the right terms but I'm thinking of things like attenuation, jitter, propagation and impedance.
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
Fan-out is the term.
It's the number of inputs a single output can drive. For most ICs, it's typically "a handful."
You would also have to worry about signal integrity due to reflections caused by impedance mis-match, but that's not usually a big deal for slow, short-length signaling like SPI.
