thinkURbetter
Display Extensiom
Sun Feb 21, 2016 11:18 pm
Hey, I'm new here and I just got a Raspberry Pi 2 and am looking to add a touchscreen TFT LCD display to it (3.5", possibly the PiTFT by Adafruit). Is there an extension cable or something I can use to connect the display to the Pi with a distance of at least 10 cm? I basically need to use the display with a cable connecting it to the Pi. Any solutions? Thanks.
DirkS
Re: Display Extensiom
Sun Feb 21, 2016 11:55 pm
There are GPIO extension cables available in various lengths
Or you could make your own. It's not that hard to do.
thinkURbetter
Mon Feb 22, 2016 12:14 am
Is that all I would require to increase the distance? Thanks for the quick reply btw.
DirkS
Mon Feb 22, 2016 2:35 am
thinkURbetter wrote:Is that all I would require to increase the distance? Thanks for the quick reply btw.
You have to be careful when buying a cable though. It's easy to get one with the connectors the wrong way around.
fdufnews
Mon Feb 22, 2016 7:44 am
Be aware that, increasing the distance too much may force you to slow down the SPI clock as the cable has a negative impact on clock bandwidth.
thinkURbetter
Mon Feb 22, 2016 7:59 pm
Okay. Thanks!
tinylcd
Tue Feb 23, 2016 4:24 am
Hello
Are you looking for a similar product with a single display ?
http://www.neosecsolutions.com//product ... 9&cPath=20
regards
tinylcd
thinkURbetter
Fri Feb 26, 2016 12:31 am
I was looking for one with a single display. Thanks and sorry for the late response.
tinylcd
Sat Feb 27, 2016 4:25 am
Hello
we can also support you with single display
PM your contact details
regards
tinylcd
thinkURbetter
Tue Mar 01, 2016 1:01 am
Sorry for the late reply. Okay thanks.
