PaddleStroke
Driving lcd with rpi only
Mon Jan 25, 2016 11:20 am
Hi everyone,
I was wondering if it is possible to monitor a lcd panel (with a lvds and inverter output) with the raspberry alone (using the GPIO connector).
Is it possible with software only or does it needs hardware add-on?
Thanks,
Pierre
DirkS
Re: Driving lcd with rpi only
Mon Jan 25, 2016 12:13 pm
You need an HDMI to LVDS converter.
Something like http://www.ebay.com/itm/HDMI-DVI-VGA-Dr ... 1115624120
And you have to make sure it's compatible with your pannel
PaddleStroke
Mon Jan 25, 2016 12:59 pm
Actually I was wondering if we can skip the converter board (lvds to hdmi) by wiring directly lvds to the raspberry gpio and make a bit of software/driver to make it work.
Any ideas?
DirkS
Mon Jan 25, 2016 1:17 pm
PaddleStroke wrote:Actually I was wondering if we can skip the converter board (lvds to hdmi) by wiring directly lvds to the raspberry gpio and make a bit of software/driver to make it work.
Any ideas?
Well, I said 'need', as in mandatory.
So the answer is no. Or in other words: yes, you need extra hardware.
