thof
[SOLVED] PCF8523 loses time on reboot
Wed Jan 06, 2016 6:01 pm
Hi all,
First of all I'm not sure if this is the right subforum, so admins feel free to move it...
I have a PCF8523 connected to a Raspberry Pi 2 B. I load the drivers through dtoverlay=i2c-rtc,pcf8523
The drivers are loaded and communication works with hwclock --debug for example, but after boot hwclock -r gives:
hwclock: The Hardware Clock registers contain values that are either invalid (e.g. 50th day of month) or beyond the range we can handle (e.g. Year 2095).
I can correct it with hwclock -w and after this it read correct. But when I reboot it is reset again...
Digging into the datasheet of the PCF8523 it reads that it's default switching state is disabled, meaning it will only work with VDD power.
See: http://www.nxp.com/documents/data_sheet/PCF8523.pdf page 15
Is this something that is wrong in the driver? Can I do something the set the registers differently to make it switch on power loss?
Thanks!
Thanks!
mikronauts
Re: PCF8523 loses time on reboot
Wed Jan 06, 2016 6:26 pm
Did you add a battery for the RTC to run from when main power is off?
thof wrote:Hi all,
Thanks!
Thanks!
thof
Thu Jan 07, 2016 8:29 am
Yes I did, I checked all connections and while digging through the datasheet it looks like this is the default behaviour. So I could try to interface with it and change the power switching mode, but I'm not sure it is stored or if it should be changed in a linux driver?
Thu Jan 07, 2016 10:34 am
Have you tried writing the current time to the RTC? sudo hwclock --systohc. Shut the system down, pull power, reboot and read the clock with sudo hwclock.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
PhilE
Thu Jan 07, 2016 10:37 am
1) Remove fake-hwclock
pi@raspi ~ $ sudo apt-get remove fake-hwclock
pi@raspi ~ $ sudo update-rc.d -f fake-hwclock remove
pi@raspi ~ $ sudo rm /etc/fake-hwclock.data
2) Re-enable the pre-systemd hwclock-set script
pi@raspi ~ $ sudo nano /lib/udev/hwclock-set
# comment out these three lines
#if [ -e /run/systemd/system ] ; then
# exit 0
#fi
3) Add dtoverlay=i2c-rtc,whatever to config.txt
4) Reboot with network
5) Wait for the time to settle
6) sudo hwclock -w
7) Unplug network and reboot
8) See that the time is correct.
thof
Thu Jan 07, 2016 12:21 pm
Excellent! I already removed fake-hwclock, but commenting out those lines seems to have done the trick!
Thanks!
Thu Jan 07, 2016 12:54 pm
thof wrote:Excellent! I already removed fake-hwclock, but commenting out those lines seems to have done the trick!
Thanks!
Shouldn't that stuff be done with a simple switch in /etc/defaults/hwclock to make it easier to find and amend. Editing bash scripts to hack three lines of code isn't the stuff that new/novice users should be doing.
MQTT Evangelist
thof
Re: [SOLVED] PCF8523 loses time on reboot
Thu Jan 07, 2016 12:59 pm
It would be interesting to see in what situations this modification would be necessary, for me it's no problem doing this, but I would not have come up with this myself...
Thu Jan 07, 2016 1:32 pm
thof wrote:It would be interesting to see in what situations this modification would be necessary, for me it's no problem doing this, but I would not have come up with this myself...
It looks like everyone running Raspbian Jessie with a RTC chip connected needs to do that stuff. It should be a
# Do you have a hardware RTC
HWRTCINSTALLED=yes
in /etc/defaults/hwclock and the program Phil got you to edit would just do the right thing.
MQTT Evangelist
jnavratil
Mon Jan 25, 2016 11:47 pm
Thanks PhilE!
I do agree with 'DougieLawson' that this behavior should be more directly configurable. I'm not a sysadmin by any stretch and like 'thof' would have had a devil of a time coming up with a solution. What I'm more concerned about is ongoing maintenance. I can imagine a fix unfixing my fix. Should I be worried?
thof
Thu Jan 28, 2016 1:34 pm
Hmm, while the solution works for Jessie, under Wheezy this does not work...
Removed fake-hwclock, edited /lib/udev/hwclock-set (although this shouldn't matter because there is no systemd).
Now after a reboot I'm getting my original error again:
thof
Thu Jan 28, 2016 1:47 pm
Oke, solved it again...
in the file /lib/udev/hwclock-set you have to change two occurences of --systz to --hctosys:
if [ yes = "$BADYEAR" ] ; then
    /sbin/hwclock --rtc=$dev --hctosys --badyear
else
fi
stg45
Wed Oct 11, 2017 8:05 pm
I have two Adafruit PCF8523 RTC which installed on my Raspberry Pi 2B and 3B. In both cases the PCF8523 have a coin battery correctly installed to ensure successful operation in the event of a power failure or reboot.
I have followed all the instructions, however when I reboot the system time is not being set correctly from the PCF8523, no errors are being reported in syslog. After I do login the date has revert back to 2011 and so has the hwclock.
I am currently using Ubuntu Mate on both.
I am currently using the pair for NTP (client and server), DNS Server (with DNSSEC enabled) and DHCP (with DHCP Failover configured).
As DNSSEC requires an accurate time, I need to be able to get DNS working with a fairly accurate clock and then allow more precise time once NTP has started.
Any advice would be gratefully received
stg45
Sun Oct 15, 2017 11:19 am
I found some instructions on the Ubuntu form which I had to adapt to get to work on my Raspberry PI 2 B and 3 B servers.
If you have followed the previous instructions then you need verify that the hwclock works correctly.
In order to get the PI to read from the RTC you need to
Step 1: Edit the file "/etc/systemd/timesyncd.conf" with the following entries:
[Time]
NTP=0.europe.pool.ntp.org 1.europe.pool.ntp.org 2.europe.pool.ntp.org 3.europe.pool.ntp.org
FallbackNTP=0.europe.pool.ntp.org 1.europe.pool.ntp.org 2.europe.pool.ntp.org 3.europe.pool.ntp.org
Step 2: Update the file "/etc/rc.local" by adding the following lines:
[ ! -e /var/lib/systemd/clock -a "`systemctl is-active systemd-timesyncd | grep -i active`" ] && timedatectl set-ntp 1 > /dev/null 2>&1
Step 3: Create a file “/etc/systemd/system/hwclock-sync.service” with the following contents:
[Unit]
Description=Time Synchronisation from RTC Source
After=systemd-modules-load.service
RequiresMountsFor=/dev/rtc
Conflicts=shutdown.target
[Service]
Type=oneshot
ExecStart=/sbin/hwclock -s
TimeoutSec=0
[Install]
WantedBy=time-sync.target
Step 4: Now we need to shutdown and disable services for "ntp" and "fake-hwclock" and remove the corresponding packages that come by default with the OS by executing the following set of commands on the "root" shell prompt:
systemctl stop fake-hwclock
systemctl disable fake-hwclock
apt-get -y remove fake-hwclock
Step 5: To finally enable the automatic start-up of the RTC synchonrisation during bootup using the "systemd-timesyncd" service, execute the following commands on the shell prompt:
systemctl enable hwclock-sync systemd-timesyncd
systemctl start hwclock-sync systemd-timesyncd
Now verify correct operation by using the timedatectl command to obtain results similar to below
Local time: Sun 2017-10-15 12:13:55 BST
Universal time: Sun 2017-10-15 11:13:55 UTC
RTC time: Sun 2017-10-15 11:13:55
Time zone: Europe/London (BST, +0100)
Network time on: yes
NTP synchronized: yes
RTC in local TZ: no
If you get the report that NTP synchronised : no after 5 minutes, then
Step 6 Install ntp
apt-get install ntp
edit /etc/ntp.conf and add
server 0.europe.pool.ntp.org
server 1.europe.pool.ntp.org
server 2.europe.pool.ntp.org
server 3.europe.pool.ntp.org
run the following commands to activate ntp
$ sudo systemctl enable ntp
$ sudo systemctl start ntp
After five minutes, run ntpq and use the command peers to show the clocks ntp is synchronised with
ntpq> peers
You can then run timedatectl and NTP should show synchronised
Who is online
Users browsing this forum: mattmiller and 15 guests
