hi, i´m Stephan and I want to do a soundprojekt on pi zero. at the moment i´m not the lucky guy to have one in my hand.
so is there a i2s port on header pins on pi zero that i could use it in the future?
Re: i2s port on header pins Rpi zero
The Pi0 has the same GPIO pin setup as the other Pi's which have I2S. However, the zero does not have the header soldered on, so you will need to do that, or solder wires direct to the board.
you may find this blog post by HiFiDuino useful:stroh wrote:hi, i´m Stephan and I want to do a soundprojekt on pi zero. at the moment i´m not the lucky guy to have one in my hand.
Specifics:
GPIO 18 (Pin12) is BITCLOCK;
GPIO 19 (Pin 35) is LRCLOCK;
GPIO 20 (Pin 38) is DATA IN;
GPIO 21 (Pin 40) is DATA OUT;
Doug.
