Page 9 of 10
Re: KeDei 3.5 inch 480x320 TFT lcd from ali
Posted: Sun Jun 18, 2017 11:20 am
by saper_2
iiAlphaWolf wrote:Hey everything is intresting and stuff, i cant help you but you can help me lol. How the heck did you make the screen even work? I put it on my pi i see backlight but no screen i do all codes they tell me still black screen... wth
What u have: display version, which RPi (1/2/3/0) , are the driver u try for exactly your display and RPi?
Posted: Fri Aug 04, 2017 4:07 pm
by Gatchaman
Thank you everyone for looking into this.
I would have never ordered the Pi3 and 3.5" kedei lcd screen from A+++ Electronics Maker, China (Guangdong) on Ali-X if I'd known how bad the situation was with this screen. :(
I have a V6.3 screen.
Posted: Fri Aug 04, 2017 9:39 pm
by saper_2
Yeah, KeDei SPI lcd are sh**** , the HDMI version is really nice - have it , and reviewed it :).
Anyway, all SPI lcd's for RPi are slow - there are "bad ass coders" (in very positive meaning :D ) who can push those LCDs to their limits - e.g. bitbank - respect for your knowledge :) .
At best, I can offer u advice: when you look at lcd, check how many chips are on the board - if it have 4 chips (in SO-14/SO-16 or don't have chips at all - e.g. some 3.95" LCD have 8bit parallel interface - got one of this kind too) then this display might work with fbtft (with little configuration). Those 4 chips usually ale lined up together (and those are: 2x 74HC4094 + 1x 74HC04 + 1x 74HC4040 ).
As for kedei spi v6.3, U can get compiled kernel from kedei www: http://kedei.net/raspberry/raspberry.html for Pi3 ....
Notice to the picture: I don't have this particular display model (I have it on my buy-list) so I can't tell what exactly driver it use.
Posted: Sun Aug 06, 2017 8:47 am
by NMaas
Dear KeDei-haunted fellows,
seems like I'd have to join you as well. I needed some 3.5 screens for an project, long story short: Now I got 6 of the KeDei v. 6.3 sitting here doing nothing - because, you know - driver situation.
I found following Github repo, which might be interesting for the 6.2 users:
https://github.com/lzto/RaspberryPi_KeDei_35_lcd_v62
However, I can acknowledge that this 6.2 test does not work with the 6.3 screen - sadly.
(Seems like v.6.3 is sold on ebay and aliexpress most of the time now...)
However, 6.1, 6.2 and 6.3 now seemingly got the same driver ( http://kedei.net/raspberry/raspberry.html ) so there should be some way to get all 6.1-3 displays controlled in a very similar way (I guess they only change the major version if the HW designs breaks drivers, with the exclusion of 6.0 as that seems to be another beast - again).
Also, Osoyoo, which seems to be one of the biggest sellers of those Displays is really refusing to handing out the drivers ( http://osoyoo.com/2016/09/13/install-ra ... an-jessie/ ). Maybe applying some presure could help ;)?
EDIT:
The 6.3 Version uses 3x 74HC595D - and thats it. Only the TS (HR2046 1703) and a voltage regulator.
The TS seems to be compatible with the XPT2046 or https://www.ti.com/lit/ds/symlink/tsc2046.pdf
Posted: Sun Aug 06, 2017 2:49 pm
by saper_2
Yeah.... We know this is sucks :(
Nice finding :)
I can guess, that v6.3 don't have that same register map as v6.2 so it won't work - while kernel for v6.1-6.3 set all registers even those that don't have 6.2 but have 6.3 ( and opposite).
You'd need to contact directly kedei, but they don't give sh*t or don't understand :lol: , I had somewhere QQ contact address to kedei, but I'm not really ready-to-install this app on my phone and/or PC - win10 is enough of spyware for me...
EDIT:
Those are standard serial to parallel shift registers (with latched outputs).
Hmm, next clone of XPT2046 , now it's HR2046 :D ("1703" - 2017 year, 3rd week :) )
I wonder if Conjur and/or 1n4148 would spare some time, and published init dumps for v6.x kernel-driver from kedei. Probably the "6.2" code that you found, might be easily adopted (I think just adding few more lines to init sequence) to support all 6.x versions...
Well, I'm still surprised that kedei is still continuing releasing this junk (probably because people just buying this without doing some research before), it's really not difficult to add one more chip and replace those 3x'595 with 2x74HC4094+74hc4040+74hc04 - so we get a normal fbtft compatible spi to parallel interface...
ehhh.... It's much harder to each time edit code and recompile kernel than change a few lines (init seq.) in fbtft kernel module config file....
Posted: Sun Aug 06, 2017 11:20 pm
by lzto
6.1, 6.2 and 6.3 have different init sequence afaik.
I only have version 6.2 in hand so I only did it for 6.2 though I can do the same thing for 6.1 and 6.3.
:ugeek:
Posted: Mon Aug 07, 2017 12:24 am
by NMaas
lzto wrote: 6.1, 6.2 and 6.3 have different init sequence afaik.
:ugeek:
At the moment I still got the 6.3 display, so I could test it, if there was a way to get the init sequence out of that thing :)
Posted: Mon Aug 07, 2017 12:28 am
by NMaas
Nice finding :)
Most probably you're right :)!
As long as there are people accidentally buying those... they won't change their minds I presume :/
That would be awesome - and help out other ppl as well :)
Oh yes... That is for sure... And what they're doing - is a nightmare for their sellers support team ^^'
Posted: Wed Aug 23, 2017 2:59 pm
by wtm
Hello! (my first time to comment :D)
I've got the same lcd display as yours (version 1.1, identical). Your code (on GitHub) ran perfectly on my RasPi 3 (the issue on GitHub is opened by me).
Now my problem is,
  1. I want to know how the color number works, as in test 4 in your repo. As your code wrote, RED is 0xF800, GREEN is 0x07E0, and BLUE is 0x001F. That means RED and BLUE has 5 bits each, but GREEN has 6 bits(0000 0111 1110 0000). I don't quite understand that.
  • Have you ever tried to make use of the touch feature? I want to read touch events, just to make some very basic applications, like buttons. It seems that ads7846 needs to be enabled in /boot/config.txt, by putting the line
    dtoverlay=ads7846
    or something like that.
    But when Pi started up with that line, the SPI device just disappeared, and I can't get touchscreen either.
Help please!
Posted: Wed Aug 23, 2017 3:40 pm
by wtm
Hello.
I've got the same KeDei lcd as yours. They should be identical, as mine is also version 1.1. I use it with my RPI 3, but recently I found that my kernel version is tooo old, and I decided to do an upgrade, and boooom...
Now I don't want to install the "driver" again. Instead, I want to control it with some codes, as you did.
Your code on GitHub worked perfectly. But I have two problems here:
  1. How does the color code function? In test 4, RED is 0xF800, GREEN is 0x07E0, and BLUE is 0x001F. I converted them into binary and found that GREEN has 6 bits (0000 0111 1110 0000), while RED and BLUE only have 5 each. Why is that?
  • How can I make use of the *touch* screen? I want to implement some basic applications, like drawing a button and read events to detect if the user touches on the button.
Thank you!
Posted: Mon Aug 28, 2017 12:19 pm
by just_zhenya
Hello guys
I have v5.0 lcd with this code https://github.com/FREEWING-JP/Raspberr ... 35_lcd_v50
Why it takes 2 spi_write on each pixel (3 bytes * 2)?
Why not send 6 bytes at once? Why is doesn't work?
Why I can't send array of pixels?
Posted: Mon Aug 28, 2017 3:01 pm
by bitbank
If this display behaves like the KeiDei 3.5" SPI display that I have, (HX8357 controller), then you can also try using my C code to talk directly to it. I wrote a library to send the data as efficiently as possible to the LCD (sending as many bytes as possible in each write). You can compile it to use the kernel SPI/GPIO drivers, WiringPi, bcm2835 or PIGPIO libraries:
https://github.com/bitbank2/SPI_LCD
Posted: Tue Aug 29, 2017 8:54 pm
by just_zhenya
Nice try but it doesn't work for me.
My module doesn't even have D/C pin!
Posted: Tue Aug 29, 2017 10:11 pm
by bitbank
Please post a picture of the labeled connector of the LCD board.
Posted: Wed Aug 30, 2017 5:39 am
by just_zhenya
Posted: Wed Aug 30, 2017 1:43 pm
by bitbank
It looks like they switched LCD controllers on that model display. It doesn't need any GPIO lines for D/C nor RESET. It just has the 2 SPI chip selects for the touch controller and LCD controller. My SPI LCD code is designed for LCD controllers which require an external line to switch between D (data) and C (command). Do you know if FBTFT supports that display? If so, find out the parameters to initialize it and you'll see the name of the LCD controller. I might buy that display to add support to my library.
Posted: Mon Sep 18, 2017 10:48 am
by Gatchaman
You can read my 1 star feedback dated 03 Sep 2017 04:36 on AliExpress. Took a long time for the feedback to be posted though. Not sure why.......
https://www.aliexpress.com/item/3-5-TFT ... 57521.html
Posted: Sun Nov 05, 2017 7:39 am
by Krot
Guys hello!
I have such a screen:
https://cdn1.savepice.ru/uploads/2017/1 ... 2-full.jpg
I downloaded from here: http://kedei.net/raspberry/raspberry.html
file: LCD_show_35hdmi_vertical
Through the console, I started the file inside the archive, and the drivers were installed.
But after rebooting the black screen is all the same!
I clicked all the files and still there is no image.
I'm ready to break this accursed screen!
Nothing works!
Posted: Tue Nov 14, 2017 6:24 pm
by saper_2
Guys hello!
Nothing works!
! DUPLICATE ! viewtopic.php?f=45&t=175616#p1220170
Don't mix HDMI wqith SPI version.
Sorry, we (I) can not help you more, change power supply (cable?) and if this can not help than you display is bad....
Posted: Thu Nov 16, 2017 4:58 am
by R0ss
Translated from taobao site. All Kedei LCD driver/image can be downloaded at pan.baidu.com/s/1kVKsAF1
It has two ways to use their SPI LCD.
a. Kernel method. Use the ready-to-use img file.
b. Driver method. To install the overlay driver
tar -xzvf LCD_show_v6.tar.gz
cd LCD_show_v6
sudo apt-get update
sudo ./LCD_backup
sudo ./LCD35_v
to switch back to HDMI :
sudo ./LCD_hdmi
to restore to the state prior to the driver installation
sudo ./LCD_restore
Posted: Tue Jan 09, 2018 8:07 pm
by Phaax
Signed up just to say thank you for finding this. It actually works on my 6.3 screen!!
The demo bitmap image is mirrored though, and the screen fills are wrapping around the edges of the screen a little bit... But it's something! :D
Since this works (for me at least), is there any way I can get the screen working with tinydrm? Is there any compatible overlay (I think that's what I need?) available? If not, how would I translate this demo into one?
Edit: I looked closer at the drawing code and it seems to actually work exactly as it is supposed to. Don't know why the image is mirrored though, but the screenshot on the github page also shows a mirrored bitmap... Soooo, I can draw rectangles - yay!
Edit 2: Rewrote the bitmap loading routine and that works too now. :D
Posted: Sat Mar 24, 2018 3:37 pm
by chkr
I can also acknowledge that the V6.2 code https://github.com/lzto/RaspberryPi_KeDei_35_lcd_v62 is not working with my V6.3 display.
But i have modified the code to work with the V6.3 Display. You can find it on github:
https://github.com/cnkz111/RaspberryPi_KeDei_35_lcd_v62
The code uses wiringPi library for SPI and is therefore quite slow. Using the kernel SPI driver will increase the data throughput to the display by more than a factor of 10!
I think this is a nice display to show stuff in parallel to the HDMI interface. SW just runs in the user-space.
Posted: Sun Mar 25, 2018 7:39 pm
by yuber1992
adquiri esta pantalla
kedei
3.5 inch SPI TFTLCD
480*320 16bit/18bit
version 6.3 2016/11/1
y ya estoy cansado de tanto probar controladores alguien prodriadarme una solucion
Posted: Sun Mar 25, 2018 8:22 pm
by saper_2
kedei
3.5 inch SPI TFTLCD
480*320 16bit/18bit
This is English forum, translate your question/problem to English, or please go to your language-specific sub-forum: viewforum.php?f=90.
Posted: Mon Mar 26, 2018 3:33 pm
by yuber1992
kedei
3.5 inch SPI TFTLCD
480*320 16bit/18bit
