I2C
Posted: Tue Aug 18, 2015 4:39 pm
by Jan1
Which I2C library is the best ( these days) for using with Python?
Is there any tutorial how to use I2C ?
Re: I2C
Posted: Tue Aug 18, 2015 4:47 pm
by Laurens-wuyts
You can use Pigpio
Laurens
Re: I2C
Posted: Tue Aug 18, 2015 5:15 pm
by joan
The standard solution is the Python smbus module. As Laurens-wuyts points out you can use (my) pigpio's in-built I2C support if smbus doesn't do what you need.
Re: I2C
Posted: Tue Aug 18, 2015 6:50 pm
by Jan1
Thank you for the replies
At the moment I have:
Windows (running a program there) --> USB/I2C bridge --> device I need to control via I2C bus
I know( from a reverse engineering) how the program communicates and how controls the device .
Now I would like to write my own program( preferably )in Python.
So, I think with Raspi It could be
RasPi --> device
( so Raspi would work also as USB/I2C bridge.Is it so?)
So, will be smbus module enough?
Is there any tutorial/documentation?
Re: I2C
Posted: Tue Aug 18, 2015 7:08 pm
by joan
I2C and SMBus is used to communicate with devices connected to one of the Pi's two I2C buses. The buses are implemented as gpios on the expansion header.
Are your devices connected to the expansion header?
Re: I2C
Posted: Tue Aug 18, 2015 7:29 pm
by Jan1
At the moment I run a program on windows that communicate ,via USB to USB/I2C bridge, with I2C bus on the device.
How should (or how can I ) connect the device to the expansion header?
Re: I2C
Posted: Tue Aug 18, 2015 7:53 pm
by joan
You generally connect the 3V3, ground, SDA, and SCL pins to the appropriate pins on the device with jumper wires.
There should be plenty of diagrams such as http://fritzing.org/media/fritzing-repo ... 017_bb.png
It would help if you could mention the device model or type of device.
Re: I2C
Posted: Wed Aug 19, 2015 10:10 am
by Jan1
Thank you for the reply.
Will I2C (Pigpio)work with the older model of Raspi. Mine has a date 2011,12 .
Are the SDA/SCL pins the same?
Re: I2C
Posted: Wed Aug 19, 2015 10:20 am
by joan
Jan1 wrote:Thank you for the reply.
pigpio and the Python smbus module should work with all models of Pi.
There were some changes between Pi models.
Could you post the contents of /proc/cpuinfo? We only actually need the revision line. That should confirm your model.
See http://elinux.org/RPi_HardwareHistory
Re: I2C
Posted: Thu Aug 20, 2015 5:11 pm
by Jan1
Thanks for the reply.
/proc/cpuinfo is
Processor : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000d
Serial : 00000000ad4e3bc3
Is it OK for Pigpio ?
Re: I2C
Posted: Thu Aug 20, 2015 5:13 pm
by joan
Yes, that will be fine.
Re: I2C
Posted: Fri Aug 21, 2015 10:35 am
by Jan1
Thank you for the reply. I tried to install PIGPIO but I received an error
[email protected] ~/PIGPIO $ make install
sudo install -m 0755 -d /opt/pigpio/cgi
sudo install -m 0755 -d /usr/local/include
sudo install -m 0644 pigpio.h /usr/local/include
sudo install -m 0644 pigpiod_if.h /usr/local/include
sudo install -m 0755 -d /usr/local/lib
sudo install -m 0755 libpigpio.so /usr/local/lib
sudo install -m 0755 libpigpiod_if.so /usr/local/lib
sudo install -m 0755 -d /usr/local/bin
sudo install -m 0755 -s pig2vcd /usr/local/bin
sudo install -m 0755 -s pigpiod /usr/local/bin
sudo install -m 0755 -s pigs /usr/local/bin
sudo python2 setup.py install
sudo: python2: command not found
make: *** [install] Error 1
Can you please help?Thanks
Re: I2C
Posted: Fri Aug 21, 2015 10:51 am
by joan
You don't seem to have Python set up in the expected way.
May I ask what cat /etc/os-release reports?
Do an ls /usr/bin/pyth* to see which versions of Python you have installed.
$ ls /usr/bin/pyth*
/usr/bin/python            /usr/bin/python2-config  /usr/bin/python3m
/usr/bin/python2           /usr/bin/python3         /usr/bin/python-config
/usr/bin/python2.7         /usr/bin/python3.4
/usr/bin/python2.7-config  /usr/bin/python3.4m
Then use the following command for each version of Python you might use.
sudo pythonx.y setup.py install
e.g. sudo python3.4 setup.py install
Re: I2C
Posted: Fri Aug 21, 2015 11:00 am
by Jan1
Thank you for help.
[email protected] / $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
[email protected] / $ ls /usr/bin/pyth*
/usr/bin/python /usr/bin/python3 /usr/bin/python3.2mu
/usr/bin/python2.7 /usr/bin/python3.2 /usr/bin/python3mu
I tried
[email protected] / $ sudo python3.4 setup.py install
sudo: python3.4: command not found
Do you have any idea where can be a problem?
Re: I2C
Posted: Fri Aug 21, 2015 11:24 am
by joan
There is no problem as such, you just have a pretty old software version, which isn't set up like the more recent Pi distributions.
You have Python 2.7 and 3.2.
So I'd use
sudo python2.7 setup.py install
and
sudo python3.2 setup.py install
Re: I2C
Posted: Mon Aug 24, 2015 12:55 pm
by Jan1
Thank you for your reply.
So I upgraded and now it works.But can you please help me how to send the commands to get the result like this
[img]
[/img]
Re: I2C
Posted: Mon Aug 24, 2015 12:57 pm
by Jan1
I tried
pi = pigpio.pi() # Connect to local Pi.
handle = pi.i2c_open(0, 0x08, 0)
pi.i2c_write_byte_data(handle, 0x08 , 0x80)
but received an error
File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 2237, in i2c_write_byte_data
self.sl, _PI_CMD_I2CWB, handle, reg, 4, extents))
File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 796, in _u2i
raise error(error_text(v))
pigpio.error: 'I2C write failed'
Thank you for help
Re: I2C
Posted: Mon Aug 24, 2015 1:22 pm
by joan
Have you checked the device is seen on the bus?
i2cdetect -y 0
Re: I2C
Posted: Mon Aug 24, 2015 2:02 pm
by BMS Doug
Have you removed i2c from the blacklist?
I2C setup for older versions of raspbian required you to do this manually by editing /etc/modules to enable i2c and editing the blacklist to remove the i2c blacklist /etc/modprobe.d/raspi-blacklist.conf
reading the adafruit page I linked above will help with setting up i2c for the first time on older versions of the raspbian OS.
more recent raspbian versions use Device Tree, I am less familiar with how to enable I2C using Device Tree.
