Cole1717
8x8 matrix with 1 MCP23017
Mon Jun 22, 2015 8:57 pm
Is it possible to setup an 8x8 matrix using 1 16 IO port expander via I2C? Could you use the left 8 ports for the columns and the right 8 ports for the rows? is I2C fast enough to update 64 LEDs reliably?
Thanks.
FTrevorGowen
Re: 8x8 matrix with 1 MCP23017
Mon Jun 22, 2015 10:17 pm
Cole1717 wrote:Is it possible to setup an 8x8 matrix using 1 16 IO port expander via I2C? Could you use the left 8 ports for the columns and the right 8 ports for the rows? is I2C fast enough to update 64 LEDs reliably?
Thanks.
FWIW, some time ago I attempted something similar with 2 x MCP23008's (equivalent to 1 x MCP23017):
http://www.cpmspectrepi.webspace.virgin ... blePi.html
(Never quite got around to posting "working photo's though :( )
There are SPI versions of both chips if I2C proved "too slow". Also there's a SPI LED display driver I.C. that includes "hardware multiplexing" which makes "life much easier"!:
http://www.cpmspectrepi.webspace.virgin ... odule.html
(and, for it's more conventional use as an 8-digit display driver:
http://www.cpmspectrepi.webspace.virgin ... odule.html )
Trev.
Mon Jun 22, 2015 11:10 pm
Thanks.
It works really well with my £12 MCP23017 based matrix board.
http://www.modmypi.com/raspberry-pi/bre ... -board-kit
Code to drive that is here: https://github.com/DougieLawson/Raspber ... ter/matrix
Demo here: https://www.youtube.com/watch?v=trkmI00aYhg (that was filmed about two hours after I built the board running it with a beta version of the software).
Cole1717
Wed Jun 24, 2015 8:12 pm
Very cool. I plan on buying one of the Adafruit RGB LED matrices because they look awesome. I am more curious of the limitations of I2C and its possible applications.
Is it correct to say that SPI is great for when you have one or two "slaves", but I2C excels at having more because of the way it communicates with several other devices?
Thanks for your responses.
Wed Jun 24, 2015 10:01 pm
With I2C you can have up to eight MCP23017s before you need a bus extender.
With SPI it's usually one device per CS (chip select) pin. SPI has an advantage that it runs faster.
Richard-TX
Sat Jun 27, 2015 5:38 am
You can have 8 MCP23S17 chips on each CS pin for a total of 16 chips per Pi. I have done it.
Richard
Doing Unix since 1985.
mikronauts
Sat Jun 27, 2015 2:54 pm
Or add a demultiplexer (like I added for MCP3208's) and you could run 8 * 8 MCP23S17's for a grand total of 1024 I/O's.
http://www.mikronauts.com/raspberry-pi/ ... and-howto/
Richard-TX wrote:You can have 8 MCP23S17 chips on each CS pin for a total of 16 chips per Pi. I have done it.
