jcarnaggio
Sending data from Arduino to Raspberry Pi
Fri May 29, 2015 10:42 pm
I have an Arduino with multiple sensors attached to it to collect GPS coordinates; however, I have only been able to get that information printed to the Serial console. I would like to be able to get the data being printed to the serial console on to a Raspberry Pi as easily and as quickly as possible so I'm just wondering what the best way to do that would be.
All info appreciated.
Re: Sending data from Arduino to Raspberry Pi
Fri May 29, 2015 11:13 pm
Use the USB connection, open /dev/ttyACM0 on your RPi and read the data.
#!/usr/bin/python
import serial, string, time
output = " "
ser = serial.Serial('/dev/ttyACM0', 9600, 8, 'N', 1, timeout=1)
#while True:
#  print "----"
#  while output != "":
#    output = ser.readline()
#    print output
#  output = " "
for i in range(0,256):
  print unichr(i)
  ser.write(chr(i))
  time.sleep(1)
jcarnaggio
Fri May 29, 2015 11:14 pm
DougieLawson wrote:Use the USB connection, open /dev/ttyACM0 on your RPi and read the data.
#!/usr/bin/python
output = " "
#while True:
#  print "----"
#    print output
#  output = " "
  print unichr(i)
  ser.write(chr(i))
  time.sleep(1)
Is this possible with C++?
AndyD
Fri May 29, 2015 11:31 pm
jcarnaggio wrote:Is this possible with C++?
Yes, of course!
jcarnaggio
Fri May 29, 2015 11:37 pm
Yes, of course!
Would an explanation be possible? This Serial business is kind of foreign to me.
jcarnaggio
Fri May 29, 2015 11:41 pm
#!/usr/bin/python
output = " "
#while True:
#  print "----"
#    print output
#  output = " "
  print unichr(i)
  ser.write(chr(i))
  time.sleep(1)
I tried to test this code with a program on the Uno that just printed "Hello, World!" over and over again and the output I got from the Python program was really odd. I got little squares with four characters in each one at a really inconsistent rate.
AndyD
Fri May 29, 2015 11:51 pm
jcarnaggio wrote:Would an explanation be possible? This Serial business is kind of foreign to me.
Sorry, I wasn't intending to be so short, but I was interrupted in posting. There is a huge amount of serial code on the Internet for C/C++ Linux. A quick search found this on stackoverflow. Unfortunately, I don't have a clean example that I can post right now.
AndyD
Fri May 29, 2015 11:56 pm
Dougie's code had the actual loop that reads from the serial port commented out. Try this
#!/usr/bin/python
output = " "
while True:
    print "----"
    while output != "":
    print output
    output = " "
I haven't tested it, but it appears to be reading a line of data from the serial port and printing it out.
joan
Sat May 30, 2015 12:18 am
...or just.
#!/usr/bin/python
import serial
ser = serial.Serial('/dev/ttyACM0', 9600, 8, 'N', 1, timeout=5)
while True:
    print(ser.readline())
jcarnaggio
Sat May 30, 2015 8:15 pm
joan wrote:...or just.
#!/usr/bin/python
import serial
while True:
This works, but the first couple of lines are a bit wonky. Is there any way to perfectly time it so if I wanted to print out unique lines and get them as they were printed to the serial exactly, could I do that?
ame
Sun May 31, 2015 12:00 am
#!/usr/bin/python
import serial
while True:
Yes, of course!
Your Arduino will be sending stuff all the time, so if you start the Pi program at a random time you might start receiving half-way through a transmission.
If it's just GPS NMEA strings you are dealing with then just discard any string that does not begin with "$". If you are making your own protocol between the Arduino and the Pi then make sure you insert some obvious way to detect the start of a packet, then you can use that.
will2055
Thu Jul 20, 2017 10:15 pm
#!/usr/bin/python
import serial
while True:
What type does the data become? I'm assuming they are placed as string variables. How could I do integers?
eripy
Sun Jan 14, 2018 9:13 pm
Code not stable, after 15- 20 sec I get this:
File "/home/pi/myprograms/ser.py", line 6, in <module>
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 490, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Arduino sends data continously
asandford
Mon Jan 15, 2018 1:37 am
Thread over 2 years old, things have probably moved on.
scotty101
Mon Jan 15, 2018 10:01 am
Try this instead
#!/usr/bin/python
import serial
while True:
    if ser.in_waiting > 0:
Often the python program will read data from the serial port quicker than it can be received. The line I have added checks to see if there is and data first before trying to read it.
Note: in_waiting works with PySerial version 3.0 and greater. For older versions use ser.inWaiting()
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
eripy
Mon Jan 15, 2018 8:56 pm
OK tried to add inWaiting but its the same. However I see that Arduino serial monitor is disturbed by the python program on Raspberry
Analog: 293 , 285 ( 966 )
Analog: 293 , 285 ( 969 )
Anal Ana95An8 ) A A4Anal ) Ana)
Analog: 301 , 291 ( 993 )
Analog: 302 , 293 ( 996 )
Mon Jan 15, 2018 9:10 pm
Can you post your Arduino sketch?
You can't run the IDE serial monitor while you're running the python program.
eripy
Mon Jan 15, 2018 10:29 pm
Thanks, closing the Serial monitor solved the problem
the Arduino code just uses Serial.print
Next I will try to get it out on Ethernet :-)
