jsmith7342
RasPi Touchscreen 5-7"
Fri Apr 03, 2015 3:47 am
Hi guys,
I'm looking to purchase Raspberry Pi 2 and a touchscreen to go along with it. I found a disturbingly small amount of information regarding touchscreens for the Raspberry Pi (I'm looking for something around 5 to 7 inches, you can't really see anything below 5 and above 7 is a bit over budget. Does anyone know if this touchscreenhttps://www.tindie.com/products/DIGCM/7 ... anana-pro/ or this http://www.aliexpress.com/item/Banana-P ... 74237.htmlwould work? Or is there another option - preferably below $100? It would also be nice if it is 5v 1a powered w. no extra boards etc... as pictured:
Thanks in advance :D ,
tinylcd
Re: RasPi Touchscreen 5-7"
Fri Apr 03, 2015 5:33 am
Hello
there are 7 inch HD screen (1024x600) available with touch on this link meeting your size and budget
http://www.neosecsolutions.com//index.p ... a9c4a6b9e8
regards
tinylcd
jsmith7342
Fri Apr 03, 2015 7:00 am
Thanks for the reply,
Would you happen to know what the power requirement is? I am planning to power both Pi and display from a powerbank with 2 outputs (5V 1A and 5V 2.1A - for my pi).
tinylcd
Fri Apr 03, 2015 7:41 am
hello
5V 3A power supply will be supplied along with this display which can power both display as well as Pi2
provison of cable is made to power Pi2 from display pcb
regards
tinylcd
tinylcd
Fri Apr 03, 2015 7:43 am
Hello
optionally 5V 1A from your power bank is enough for the display alone
regards
tinylcd
jsmith7342
Sun Apr 05, 2015 5:45 am
Hi, thanks for the reply.
I noticed some other displays on eBay and Amazon which are around $50 - it would be nice if I could get one that cheap. Anyone know if these work:
http://www.amazon.com/Tontec%C2%AE-Rasp ... ouchscreen
http://www.amazon.com/Resistive-interfa ... ouchscreen
http://www.amazon.com/SainSmart-Display ... ouchscreen
I don't want to buy something dodgy... and preferably get a display which doesn't use up my GPIO pins...
DirkS
Sun Apr 05, 2015 9:55 am
jsmith7342 wrote:Hi, thanks for the reply.
They all have HDMI input, so I would expect them to work. Be aware that only #2 has a touch panel and it uses some of the GPIO pins:
HDMI interface for displaying, no I/Os required (however, the touch panel still needs I/Os)
If you don't want to use the Pi's GPIO then you'll have to find a screen with a USB touch panel.
jsmith7342
Mon Apr 06, 2015 11:31 am
Hi again,
Anyone have any experience with this touch screen 5" from eleduino which only requires 5v 0.2A and a couple of GPIO pins? http://eleduino.com/products_ny_162.html. Does anyone know how much they charge for international shipping?
Thanks.
jsmith7342
Wed Apr 08, 2015 11:28 am
Anyone know of any touch displays around $50??? Seems weird paying more for the display than the computer itself... ;)
stainy
Wed Apr 08, 2015 2:54 pm
I just ordered one from Banggood.com
http://www.banggood.com/3_5-Inch-TFT-LC ... 60194.html
stainy
Fri May 01, 2015 1:19 pm
Trouble is with this screen from banggood. They give you drivers for the screen.. but it`s in a .img file
I don`t want that.. I just want to install the drivers on an existing installation.. .
Can anyone help ??
mikronauts
Fri May 01, 2015 2:57 pm
These displays are specific to the Banana Pi, and will NOT work with a Raspberry Pi.
You need a display with hdmi input (LCD+adapter board) and a USB touch screen controller that is supported by the Pi.
FYI, here is my review of a 4.3" hdmi LCD/adapter combo:
http://www.mikronauts.com/raspberry-pi/ ... periments/
jsmith7342 wrote:Hi guys,
lvt213
Wed Nov 18, 2015 10:18 am
Does it work well with the DSI interface ?
DO we need to install anything else or just plug and play like HDMI ?
I intend to use this screen
http://www.aliexpress.com/item/Banana-P ... 38878.html
but i am not sure how it work ?
