jerseytechguy
Getting i2c to work on Raspberry Pi2
Sun Mar 15, 2015 4:20 pm
I come from a Windows and .NET world. So a bit new to Linux and the PI.
I am trying to get i2c working on my Pi2. I am running Raspbian (most recent version for Pi2). Have gone through config and enabled I2C and SPI as both will be needed for my projects.
I am trying to get a ds1307 RTC working. From what I've read running the command below is supposed to detect the devices. However I get the following error.
sudo i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
I also tried -y 1 per another article on newer PIs and this throws same error.
I am not finding much info out there on Pi2 and I2C. Does anyone have any advice or experience with this?
Software Architect, Electronic Engineer, Car Enthusiast, Chef, Blogger, Paranormal Investigator (and Skeptic). I'm like MacGyver, Alton Brown, Doc Brown and Peter Venkman all in one.
ShiftPlusOne
Re: Getting i2c to work on Raspberry Pi2
Sun Mar 15, 2015 4:49 pm
joan
Sun Mar 15, 2015 4:55 pm
Add the following lines to /boot/config.txt and reboot.
dtparam=i2c1=on
dtparam=spi=on
The spi devices should be present if you do
$ ls -l /dev/spi*
crw-rw---- 1 root spi 153, 0 Mar 13 22:17 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 Mar 13 22:17 /dev/spidev0.1
For I2C you'll probably have to install the modules
sudo modprobe i2c_bcm2708
sudo modprobe i2c_dev
Then
 $ ls -l /dev/i2c*
crw-rw---- 1 root i2c 89, 0 Mar 15 12:54 /dev/i2c-0
crw-rw---- 1 root i2c 89, 1 Mar 15 12:54 /dev/i2c-1
jerseytechguy
Sun Mar 15, 2015 5:58 pm
I did try the steps from this thread and no luck.
ShiftPlusOne
Sun Mar 15, 2015 6:00 pm
Are the required modules loaded (check with lsmod)? Joan's post provides a bit more detail.
jerseytechguy
Sun Mar 15, 2015 6:03 pm
joan wrote:Add the following lines to /boot/config.txt and reboot.
dtparam=i2c1=on
dtparam=spi=on
$ ls -l /dev/spi*
Then
 $ ls -l /dev/i2c*
This seemed more promising and did help. Thanks!
Sun Mar 15, 2015 8:24 pm
Add these two lines to /etc/modules
i2c_bcm2708
i2c_dev
and the modprobe stuff gets run automagically during boot.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
Distro
Wed May 13, 2015 6:47 am
Try enabling I2C since the RPi's booting.
sudo raspi-config
Select 8: Advanced options.
Select A7: I2C
Then YES, OK and YES, OK for both questions RPi will ask.
Finally reboot:
sudo reboot
For now, the I2C will be enabled when you run your RPi.
Hoping it be helpful.
Regards.
Zork
Tue Feb 23, 2016 2:35 am
I have tried everything covered here, and still no success. I have confirmed I am editing the 'real' config.txt and not a copy. Dtparam=act_led_trigger=heartbeat works, but dtparam=i2c_arm=on,i2s=on,spi=on does not. I have also tried just i2c and i2c1.
FTrevorGowen
Tue Feb 23, 2016 7:37 pm
Zork wrote:I have tried everything covered here, and still no success. I have confirmed I am editing the 'real' config.txt and not a copy. Dtparam=act_led_trigger=heartbeat works, but dtparam=i2c_arm=on,i2s=on,spi=on does not. I have also tried just i2c and i2c1.
I enabled spi & i2c via raspi-config which appended two lines to /boot/config.txt with a somewhat different syntax than that above:
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=spi=on
dtparam=i2c_arm=on
(Hopefully not a "red herring")
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
joan
Tue Feb 23, 2016 8:01 pm
Things have changed since last year when that advice was given.
In addition to what FTrevorGowen says make sure /etc/modules contains i2c-dev but any other i2c or spi modules should now be commented out in /etc/modules.
Zork
Wed Feb 24, 2016 3:55 am
I have also tried the params on singular format. My modules file includes i2c-dev and i2c-bcm2708.
Zork
Wed Feb 24, 2016 4:02 am
I can get "i2cdetect -y 1" to display but "gpio load i2c" just tells me that I don't have i2c loaded and device tree is enabled.
DirkS
Wed Feb 24, 2016 8:30 am
Zork wrote:I can get "i2cdetect -y 1" to display but "gpio load i2c" just tells me that I don't have i2c loaded and device tree is enabled.
You don't need a gpio load. That's already loaded through the device tree stuff.
Also get rid of 'i2c-bcm2708' from /etc/modules.
You only need
dtparam=i2c
in config.txt and
i2c-dev
in /etc/modules
Zork
Wed Feb 24, 2016 7:05 pm
Ah, I see. I was following i structions that said to use gpio load to get an accelerometer to work properly.
