veryevil
SPIDev Frequency halves?
Sat Feb 21, 2015 1:05 pm
Hi, just started using my PI2 and trying to get SPI working.
I'm using a slightly modified version of the code listed under the heading "Using The SPI Port Without the BCM2835 Library" http://www.raspberry-projects.com/pi/pr ... -interface
Its working great after I added a memclr to the SpiWriteAndRead function, took the loop out and made it send whole packets instead of bytes.
The problem is the clock frequency seems to half randomly so I have it set for 1Mhz but sometimes it will be 500khz
I'm using a clock value of 500000 for spi_speed
ioctl(*spi_cs_fd, SPI_IOC_WR_MAX_SPEED_HZ, &spi_speed);
ioctl(*spi_cs_fd, SPI_IOC_RD_MAX_SPEED_HZ, &spi_speed);
... and later ...
spi.speed_hz = (spi_speed);
my main just sends a 6 byte packet in a loop 100 times with a second delay between each. Most are at 1Mhz but some are at 500Khz.
Any thoughts?
