AlexVend
EMG sensor and Raspberri Pi
Wed Jun 09, 2021 6:58 am
Hi guys! Can anyone help me? I have raspberry pi 3 and grove base hat (https://wiki.seeedstudio.com/Grove_Base ... pberry_Pi/). I want to connect an EMG sensor. I have already taught me how to read data in mV from sensor but I do not understand how to process this data that they were correct. Has anyone tried doing this?
import time
from grove.adc import ADC
adc=ADC()
channel=4
def main():
	def getdata():
		data=adc.read_voltage(channel)
		return data
	while True:
		Signal=getdata()
		print('EMG: {0}'.format(Signal))
		time.sleep(.1)
AlexVend
Re: EMG sensor and Raspberri Pi
Wed Jun 09, 2021 7:08 am
Here's what is output:
EMG: 3246
EMG: 1936
EMG: 92
EMG: 4
EMG: 1
EMG: 0
EMG: 0
EMG: 0
EMG: 0
EMG: 1443
EMG: 3112
EMG: 3204
EMG: 3237
EMG: 3249
EMG: 3243
EMG: 1458
EMG: 22
EMG: 0
EMG: 0
EMG: 8
EMG: 0
EMG: 9
EMG: 1493
EMG: 3138
EMG: 3224
EMG: 3231
EMG: 3249
EMG: 3255
EMG: 752
EMG: 15
EMG: 4
EMG: 1
EMG: 4
EMG: 0
EMG: 0
EMG: 0
EMG: 0
EMG: 3081
EMG: 3191
B.Goode
Fri Jun 18, 2021 8:38 am
Why do you think the reported data is not correct? What independent calibration do you have to check the results?
(It seems unlikely that the results posted were produced by the accompanying code.)
twostage
Sat Jun 19, 2021 11:02 am
The numbers you are getting back are millivolts with the max value being 4096 according to their github pages.
If you want volts then simply divide by 1000.
AlexVend
Sun Jun 20, 2021 2:03 pm
It seems strange to me that the data periodically becomes close to zero. If I disconnect the sensor from the board, the data becomes maximum and is always equal to 4096.
AlexVend
Sun Jun 20, 2021 2:05 pm
I do not calibrate the sensor because I do not know how and where it should be done.
