imsdal70
555 timer for button debouncing
Tue Jun 15, 2021 4:50 am
Will LMC 555 timer with Vcc=3V configured in ( one-shot ) mode or monostable mode work as a button debouncer connected to pi? I was thinking about clean GPIO interrupt, ( falling or rising edge )
pasman1
Re: 555 timer for button debouncing
Tue Jun 15, 2021 4:59 am
yes.
you may test software debouncer with
bouncetime
parameter.
Pi4 Linux raspberrypi 5.10.17-v8+
imsdal70
Tue Jun 15, 2021 8:48 am
thanks, I will give it a try with a 555. Software debouncer is a useful advice but sometimes I find it tricky to decide what debounce time to set.
imsdal70
Fri Jul 02, 2021 9:58 am
I have a working button debounce circuit based on the LMC 555 timer Vcc = 3,3V. It's configured in monostable mode with a positive pulse T = about 0,1 sec. When the 555 is not triggered it's output pin 3 stays LOW. Se attached picture. I have configured Pi with an interrupt, (falling edge ). What concerns me before I connect pin 3 555 to GPIO is if I should worry about how to set the GPIO ports during the initialization:
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
or
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_UP)
Does it matter how I set pull up or pull down? Given LOW at pin 3, 555 startuptime?
drtechno
Sat Jul 03, 2021 12:21 pm
or
not really because any pull up or down the output on the cmos 555 will act like a loading resistor to vcc or gnd . The ones internal to the gpio array is 100K btw.
