dckornbluh
Need advice re: shielded serial cable
Mon Apr 19, 2021 2:53 pm
I have a pi 3B+ running in a very noisy environment. The pi is connected to another computer via a foot long 4-wire serial cable. The serial protocol uses a checksum and does retries of corrupt messages. This works, but I'd like to reduce the number of retries by using a shielded cable.
The shielded cable needs to be grounded on both ends, right? I was thinking about grounding to an available GPIO ground pin, but I'm not sure if the noise translates to voltage > 3.3V. Although, one of the 4 wires in the serial cable is also a ground, and, without a shielded cable, I haven't smoked a pi yet. What's the right way to do this?
pylo
Re: Need advice re: shielded serial cable
Fri Apr 23, 2021 8:43 pm
Judging from your question, I assume you don't have a proper metal case serving as a shield, you only have the circuit grounds.
1) Don't connect your cable shield to ground on both ends, otherwise it will simply take over the role of your ground signal, which is not what you want. Connect the shield to ground only on the host end directly.
2) On the device end, either do not connect at all, or better, connect to ground over a high-valued resistor (like 1Meg). This will prevent the cable shield from floating if the shield isn't connected on the host end for any reason.
3) You can optionally connect a filtering capacitor in parallel to this resistor. But it is probably more important that the ground side of the resistor is connected at a "quiet" place to your board's ground.
4) Shielding relies not only on your shield completely (360°) encircling your cable, but equally important, also on completely (360°) encircling your connectors. Meaning your results could be limited if you don't have the proper connectors.
5) Do you know for sure what the reason for your corrupted data is? Could it be it has to do with ground loops or -offsets? Could it be it is noise coupling not from air, but from the host or from the device? To eliminate most of these problems, try using a galvanically isolated serial connection.
6) Alternatively to all the above, you could try leading most of the cable length over USB, then using an isolated serial converter, and then going only a short distance over the serial cable. USB having differential data lines, it is much more robust to noise. I can recommend the μArt as a converter. I assume you are not using RS-232, because with its voltage levels it is unlikely you'd be having issues at this distance.
jayben
Mon Apr 26, 2021 1:03 pm
If a one-foot-long serial cable is giving you problems, then the RF field strength of the interference must be extremely high, or more likely, the serial cable isn't the real problem. The interference could well be penetrating directly into the Pi or the other computer (maybe via the power supply, or other cabling) in which case it doesn't matter how much you screen the serial cable.
6by9
Mon Apr 26, 2021 1:39 pm
This was the subject of a thread only last week - viewtopic.php?f=63&t=310091
B.Goode
Mon Apr 26, 2021 2:57 pm
Fascinating -
Last week:
My pi 3B+ is running next to a compressor that makes a lot of RFI and EMI. It's connected to another computer via a foot long 4-wire serial cable. The serial protocol uses a checksum and retries messages that get back a NAK. This works, but I'd like to reduce the number of retries by using a shielded cable.
This post:
Mon Apr 26, 2021 4:06 pm
Fascinating -
Last week:
This post:
One or both are spammers.
6by9
Mon Apr 26, 2021 4:20 pm
Quite possibly, but seeing as nothing untoward has been done so far, it would be harsh to take action against either of them.
Mon Apr 26, 2021 4:25 pm
If it were my forum I'd ban both and delete both threads. Then block their spammer IP address(es).
