cthomas
How To Manually Bring Slave Select Low (SPI)
Wed Mar 25, 2020 10:54 pm
I am a beginner at raspberry pi and SPI and have two questions:
1. How do you manually bring chip select low? I am currently using a random GPIO pin that is not being used and bringing it low. I am not sure, however, if the driver will recognize that as the slave/chip select.
2. Is there a way to wait a certain amount of time between bytes during the transfer of a frame?
- I am currently using spidev but open to using any library. Is there another library more appropriate with good documentation?
- Raspberry Pi 3 Model B
This is what I currently have:
import spidev
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(37,GPIO.OUT)
spi = spidev.SpiDev()
ret = spi.open(0,0)
spi.max_speed_hz = 80000
spi.mode = 3
if  __name__ == "__main__":
	data_out = [0x01, 0x42, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
	while True:
		GPIO.output(37, GPIO.LOW)
		time.sleep(1/1000)
		for i in data_out:
			data_in = spi.xfer2(data_out)
			time.sleep(1/20000000)
			print(data_in)
		time.sleep(1)
Re: How To Manually Bring Slave Select Low
Wed Mar 25, 2020 11:49 pm
What's your SPI device?
Why don't you want to use the spi.xfer() or spi.xfer2() functions which do all the CS/MISO/MOSI stuff for you using the spidev driver?
This is a doctor free zone.
cthomas
Thu Mar 26, 2020 1:30 am
Thanks for the response. I want to be able to wait 1ms after bringing CS low before sending the first byte of data. I am unable to do that with xfer2.
joan
Re: How To Manually Bring Slave Select Low (SPI)
Thu Mar 26, 2020 6:28 am
You need to bring the pin high after the transaction.
