david_1234
Re: [quick-guide] CAN bus on raspberry pi with MCP2515
Mon Jan 01, 2018 4:21 pm
I did everything like it say in the guide
but I don't get the can interface
any idea why ?
I havetry 2-3 times - I get no error in any step ,
but I don't have "can" interface.
The mcp2515 is connected as shown in the setup
I'm using raspberry pi 2 Model B - Jessie 4.9.35-V7
waht am I doing wrong ?
Thanks ,
david_1234
Mon Jan 01, 2018 5:27 pm
don't know what I did - but I reinstall everything and now it's working :-)
now I want to do this :
run a pyton code that take the data and solve it as a simple massage
for example:
when I get 18FE320 - I will decode it as "door open"
how can I do this ?
Thanks ,
saper_2
Thu Jan 04, 2018 12:21 pm
david_1234 - for reinstalling, something u must have broken/not installed.
As for what u want, ask uncle google: https://goo.gl/e7NZmB .
Stafan Willms
Sat Feb 17, 2018 1:18 pm
thanks to this nice quick-guide i managed to access the CAN bus of my heating system at home with my pi. I can send requests with the "cansend" command and search for the response with the "candump" command. But this searching for the response is pain in the ass, and for my project i am serching for an way to get the direct response to my specific request automatic. Does anybody know if there is an command that i can use, that works in some way like this:
 [email protected]:~ $  somecommand can0 580#31000C00000000
can0 180   [7] B2 00 0C 00 19 00 00       <--- direct response to my request
Thanks for your help and sorry if my english is creepy.
Stefan
scorpion_08
Thu Mar 08, 2018 6:46 am
[email protected]:~ $ sudo ip link set can0 up type can bitrate 1000000
RTNETLINK answers: Numerical argument out of domain
when i set data rate to 1mbs, there appears an error. can you help in this regard.
david_1234
Thu Mar 15, 2018 3:19 pm
Cansome one help or guide me ?
when I connect the canbus to my car i get a lot of data
I want to see only the data I want
for example
only PID 156,111,164,265
how Do I do this?
is it something in the canutilitis I need to do ?
cansniffer?
or I need to write an external code that will read the candump and show mw only what I want ?
Thanks ,
andminsk
Tue Apr 03, 2018 3:03 pm
Hi to all?
Does anybody know - is it possible to monitor 2-3 CAN bus line with one Pi?
Using several MCP2515
gaffer206
Thu Apr 05, 2018 6:30 am
Hi to all?
You might look at https://www.sg-electronic-systems.com/e ... 2-canberry
gaffer206
Thu Apr 05, 2018 6:35 am
I've got one of these modules to try to talk to some NMEA2000 devices. A couple of questions.
How important do you think the 1uF tantalum is if the 5V supply is a good one nearby?
I had a look at the TJA1050 specs and it says the RXD pin can be 0.7 VCC which at 5V would be 3.5 V which is more than the maximum 3.3 V input for the Pi. Have you done anything about this? Do you consider it a problem?
cheers
Julian
saper_2
Mon Apr 16, 2018 10:08 pm
I always put right beside the IC always a cap 100n fo generic digital or MCU (unless datasheet suggest more) chip, for line/bus drivers I usually put on power trace close to the chip a ceramic(or tantalum) 1+uF and ceramic 100n - the 100n might be not necessary but I never had any problems where the power supply was the culprit thanks to my caution :)
U don't connect bus driver to Rpi , bus driver (MCP2551/TJA1050/etc) first need to be connected to CAN bus controller which is the MCP2515.
If u actually read my first post then U should see that I disconnected the CAN bus driver from 3,3V and connected it's power to 5V while keeping the MCP2515 powered from 3,3V. For MCP2515 this is no problem , we only have to worry for the side of MCP which talk to RPi - so that's why I power MCP2515 from 3,3V.
TJA1050: 0,7Vcc=3,5V -> I see this in output but in "conditions" columns (and this refer for RXD pin max currents) , not the min-max columns. Beside VIH is 2V this is much below 3,3V Vcc of MCP2515 :)
keyneaLai
Mon Apr 23, 2018 8:36 am
Holle:
my code:
def SendBack(data):
msg = can.Message(arbitration_id=0x000601, data = data, extended_id=False)
bus.send(msg)
bus.flush_tx_buffer()
time.sleep(0.001)
try:
	Ans = str(bus.recv(timeout=1.0))
except:
	print("Error")
	return(None)
if(len(Ans) > 10):
	return("success")
else:
	return(None)
My question is when it lost recv then i cant send any new message.
it can't send any data and any response.
I need to restart Raspberry Pi then CAN bus will be normal.
Please help me to fix this question.
Thank you
gaffer206
Sun May 13, 2018 3:09 pm
Sure. Better safe. I'll follow your advice.
Thanks - I read it but got mixed up. You are right of course.
gunahmt
Wed Jun 27, 2018 12:44 pm
Hi guys,
i have raspberry pi 3 B+. I get a problem in sending message.
cansend can0 456#1234e67890123456
bash: cansend: command not found
my kernel version is;
Linux raspberrypi 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
what is the problem?
EDIT: i installed can-utils and it is working now,but mcp2515 always sends message and i cant stop it.
EDIT 2 : i figure it out just need acknowledge message for stop.
vinnitu
Fri Jul 06, 2018 9:05 am
Hello people!
I need help too! Maybe my information will be usable.
I have stm32f103 with tfj1050 - and I can communicate with rasp
oscilator=16000000
bitrate 1000000 in /etc/network/interfaces
but it is not 1Mb! It is more like ~140Kb
why?
now I try connect arduino uno + mcp2515 + mcp2551 + 8000 oscilator via spi 1Mb - and it doesnt work...
If I change bitrate to 500Kb - it works (< 500 ofcause) but I need 1Mb - what i need to do? is it possible in general?
thank you all!
vinnitu
Tue Jul 10, 2018 7:08 am
Hello people!
oscilator=16000000
why?
thank you all!
seems oscilator=16000000 + 1000000 bps give us 500000pbs (measured with logic analyzer)
so... is it possible make work as we wish?
Vladimir Abramov
Thu Aug 09, 2018 5:41 pm
Hello. I successfully connect module to Pi 3b, configured by manual at topic start and get my nmea2000 frames. All fine.
I have only one problem. CPU usage. If even i disconnect module from bus driver still 1 core just for itself.
%Cpu(s):  0.0 us, 21.6 sy,  0.0 ni, 78.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem :   949452 total,   851924 free,    29880 used,    67648 buff/cache
KiB Swap:   102396 total,   102396 free,        0 used.   858772 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
  571 root     -51   0       0      0      0 R  71.5  0.0  10:10.95 irq/169-mcp251x
  179 root      20   0       0      0      0 S  44.7  0.0   4:25.13 spi0
Is it OK for this solution? Is there some hardware spi acceleration? Cpu usage is not a problem but heat, and device will be connected to battery and waste of power can by problem/
Vladimir Abramov
Thu Aug 09, 2018 6:28 pm
Hello i have connected to my can network using this manual but have one issue.
top - 17:34:59 up 14 min,  1 user,  load average: 0.83, 0.76, 0.49
Tasks:  92 total,   2 running,  50 sleeping,   0 stopped,   0 zombie
Driver consumes 1 core. Even without connection to network itself.
Am I doing something wrong? I'm tried to change bandwidth but changes are insignificant.
Minzent
Wed Aug 15, 2018 1:17 pm
hey guys,
I have the following problem:
I use a raspberry 3 with the latest version and a PiCAN2 RevB 09/15, everything installed following this guide -->
http://skpang.co.uk/catalog/images/rasp ... N2UG12.pdf
except that I cut out the "-overlay" in the config because otherwise it wouldnt bring up the can0 interface.
So the can0 is up and i can receive and send massages at 125 mbit/s and lower, no problem.
But i need to send and receive at 250 mbit/s.... That does not work whatsoever.
Am I missing something?
thanks
raspberry_CAN_i_?
Thu Sep 13, 2018 7:44 am
Hello sir a newbie here,
I use the exact same setup as @saper_2 ( MCP2515 and MCP2551), can0 is detected however there is no data flow from transceiver (candump can0 outputs nothing). Do I need a level-shifter or a resistor between the controller and the transceiver ?
Sorry for rewoking an old topic
vliev
Tue Nov 06, 2018 12:52 am
Hi, I am using 5v module and having 5 pins logic level shiftier from 3.3v to 5v, I am trying to remove one of Level shifter
pins are required only 5pins (SCK, MOSI, MISO, CS, INT,), However SCK is input to MCP2515, my understanding is not required to do any with this pin for level shifter. However MOSI, CS are input to MCP2515. While Vdd MCP2515 is 5.0V then Driving from RaspberryPi shoud be n problem?
maltsev.v.v
Wed Mar 06, 2019 4:55 pm
Hi, sorry for my english (google translate).
My car audi. Multimedia RNS-D Audi Navigation Plus.
There is a Raspberry pi 3 + mcp 2515.
I want to control the Raspberry pi 3 with the buttons RNS-D Audi Navigation Plus.
RNS-D Audi Navigation Plus has 2 canL / canH contacts with mcp 2515 canH canL.
mcp 2515 connects with RPI, according to the scheme on 1 page. mcp 2515 J1 Closed
sudo apt update
sudo apt upgrade
uname -a
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
sudo nano /boot/config.txt
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtoverlay=mcp2515-can0,oscillator=8000000,interrupt=12
dtoverlay=spi-bcm2835-overlay
sudo reboot
sudo apt-get install can-utils
[email protected]:~ $ ls /sys/bus/spi/devices/spi0.0
driver  modalias  net  of_node  power  statistics  subsystem  uevent
[email protected]:~ $ ls /sys/bus/spi/devices/spi0.0/net/
can0
[email protected]:~ $ ls /sys/bus/spi/devices/spi0.0/net/can0/
addr_assign_type  dormant            name_assign_type  speed
address           duplex             netdev_group      statistics
addr_len          flags              operstate         subsystem
broadcast         gro_flush_timeout  phys_port_id      tx_queue_len
carrier           ifalias            phys_port_name    type
carrier_changes   ifindex            phys_switch_id    uevent
device            iflink             power
dev_id            link_mode          proto_down
dev_port          mtu                queues
sudo ip link set can0 up type can bitrate 125000
sudo ifconfig
[email protected]:~ $ sudo ifconfig
can0: flags=193<UP,RUNNING,NOARP>  mtu 16
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.31.66  netmask 255.255.255.0  broadcast 192.168.31.255
        inet6 fe80::e656:fe49:5fb3:df98  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:f9:20:5f  txqueuelen 1000  (Ethernet)
        RX packets 1456  bytes 144323 (140.9 KiB)
        TX packets 211  bytes 29712 (29.0 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
cansend can0 456#43414e2054657374
candump can0
I click buttons on the RNS-D and there is nothing.
If I get, 1 cable from can, then random code begins to appear. But the buttons also do not respond.
[email protected]:~ $ candump can0
  can0  0B456227   [8]  43 41 4E 20 54 65 73 74
  can0       12F   [8]  remote request
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       04A   [8]  remote request
  can0       092   [1]  43
  can0       092   [1]  43
  can0  1A2B42EF   [8]  43 41 4E 20 54 65 73 74
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
  can0       092   [1]  43
what am I doing wrong?
mcp 2515
RNS-D
Hardwick
Tue May 21, 2019 8:00 am
Can anyone point me in the right direction here. | am connecting MCP2515 and MCP3008 to a Pi3 B+
I can't get the CS pins to work unless I do this:
dtparam=spi=on
dtoverlay=spi1-2cs
dtoverlay=mcp2515-can0,spi0-0-present=true,oscillator=16000000,interrupt=25
dtoverlay=mcp3008,spi1-0-present=true,spi1-0-speed=1000000
Then I get:
/sys/bus/spi/devices/spi1.0 (mcp3008)
/sys/bus/spi/devices/spi0.0 (mcp2515)
But spider maps like this:
/dev/spidev0.1
/dev/spidev1.1
If I specify spi1-0-present and spi1-1present then I get the device files accordingly but CS does not work.
This is all rather confusing and I must be misunderstand how the config file works..
Truesolutions
Thu Oct 10, 2019 8:44 am
Has any seen example using this on Pi3 running Windows Iot.
C# windows universal example would be great
