smarques
Cap1188 not detected on the pi4
Sun Oct 06, 2019 11:17 am
Hi I am trying to connect a cap1188 breakout (https://learn.adafruit.com/adafruit-cap ... t?view=all) to a pi4
I wired like here:
I have i2c installed and activated
 lsmod | grep i2c_
returns
i2c_bcm2835            16384  0
i2c_dev                20480  0
but still when I run
sudo i2cdetect -y 1
I get all empty slots
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Any hint on how to trubleshoot this?
TIA
joan
Re: Cap1188 not detected on the pi4
Sun Oct 06, 2019 8:56 pm
You haven't connected AD to 3V3.
smarques
Wed Oct 09, 2019 7:06 pm
Thank you for your reply...
at https://learn.adafruit.com/adafruit-cap ... t?view=all
it says
Wire connecting AD to 3V -> I2C address 0x28
No resistor or wire attached to AD -> I2C address 0x29
so I believe it should work both ways...
still I tried the AD->3V but nothing seems to change :(
tia for any other tips
joan
Sun Oct 13, 2019 12:21 pm
A clear photo showing the connections may be useful.
smarques
Sun Oct 13, 2019 12:46 pm
Thank you all so much, the connections as in the photo above are just fine...it turned out to be a soldering problem. Now the device works great. My bad.
Thanks again
Sergio
