rapidograf
How open second i2c port on B+
Thu Oct 11, 2018 10:39 am
How open second i2c port on Raspberry B+ . fro use i2c detect y -0 :idea:
bigest and hugest same as tiny and micro
aBUGSworstnightmare
Re: How open second i2c port on B+
Thu Oct 11, 2018 11:53 am
You can enable it by adding the relevant overlay to config.txt.
Info: Change i2c0 pin usage. Not all pin combinations are usable on all
platforms - platforms other then Compute Modules can only use this
to disable transaction combining.
Load: dtoverlay=i2c0-bcm2708,<param>=<val>
Params: sda0_pin GPIO pin for SDA0 (deprecated - use pins_*)
scl0_pin GPIO pin for SCL0 (deprecated - use pins_*)
pins_0_1 Use pins 0 and 1 (default)
pins_28_29 Use pins 28 and 29
pins_44_45 Use pins 44 and 45
pins_46_47 Use pins 46 and 47
combine Allow transactions to be combined (default
"yes")
Info: Change i2c1 pin usage. Not all pin combinations are usable on all
Info: Enable the i2c_bcm2708 driver for the i2c1 bus
Load: dtoverlay=i2c1-bcm2708,<param>=<val>
Params: sda1_pin GPIO pin for SDA1 (2 or 44 - default 2)
scl1_pin GPIO pin for SCL1 (3 or 45 - default 3)
pin_func Alternative pin function (4 (alt0), 6 (alt2) -
default 4)
"yes")
Info on all overlays (as there are some others as well) is here https://github.com/raspberrypi/firmware ... ays/README
rapidograf
Thu Oct 11, 2018 1:17 pm
"yes")
default 4)
"yes")
wow ! thank you. may be is more easy way ? or more detailed
6by9
Thu Oct 11, 2018 1:35 pm
If you want the default pin assignment for i2c-0 (normally pins 27&28 on the 40 way header), then just adding
dtparam=i2c_vc=on
is sufficient.
There are no I2C pullups on those pins - you need to add your own.
Enabling i2c-0 for use by the ARM precludes the use of the camera module or the DSI display touchscreen.
rapidograf
Thu Oct 11, 2018 1:48 pm
dtparam=i2c_vc=on
is sufficient.
id like use full compatible i2c-0 features as for i2c-1 / is it possible ?
6by9
Thu Oct 11, 2018 2:53 pm
The feature set of the two peripherals is identical.
Nominally i2c-0 is assigned to the GPU (VideoCore, or VC) for use in controlling the display and camera. There is no arbitration on the peripherals, so if both the ARM and GPU try accessing it at the same time then bad things happen as both processors try servicing the interrupts etc.
If, and only if, you are not using the display or camera then it is safe for the ARM to use the peripheral. That is what the dtparam=i2c_vc=on line does.
As to what you do with it after that point, that is totally up to you.
i2c-1 is nominally assigned to the ARM, therefore is safe to use as standard.
rapidograf
Fri Oct 12, 2018 4:57 am
sorry , i,m not clear understant , in which file necessary add dtparam=i2c_vc=on ?
6by9
Fri Oct 12, 2018 5:50 am
/boot/config.txt
rapidograf
Fri Oct 12, 2018 6:02 am
/boot/config.txt
ome last question .
in which case wil be fatal collision in together working i2c-1 and i2c-0
6by9
Fri Oct 12, 2018 6:33 am
No.
Would you expect issues if you had two serial ports on a pc?
As previously stated, the reason it is not enabled by default is that i2c-0 is nominally reserved for the Gpu, that's all.
rapidograf
Fri Oct 12, 2018 6:49 am
No.
Great thank you ! (may be isnt lexically correct byt any way great thank you)
